Fit brakes
Old Apr 17, 2006 | 01:41 AM
FireFit's Avatar
Fit brakes
Does anyone know if any of the Honda Vehicles front brake pads are compatible with the FIT.. i Need to get some aftermarket brake pads for it. But I doubt that They have pads for it since the car is new to the market.
Old Apr 17, 2006 | 03:44 AM
vividjazz's Avatar
Someone that Posts too much
Same pads as other Hondas with 1513 capliers. Wether any Hondas sold in North America have these calipers I can't answer that. Pads from a compatible Honda would not offer improved performance.
Spoon, Endless, EBC greenstuff, Mugen, J's Racing, Bendix, Ferodo, Winmax and heaps of others. With over 1 million Jazzes/Fits sold worldwide since 2001 there are heaps of pads and parts.
Old Apr 25, 2006 | 03:53 AM
AJ PwR Jr.'s Avatar
Former Vendor
I did make a cross reference check but the Fit pads doesnt match up other USDM model Hondas
Old Feb 22, 2008 | 09:38 PM
mahout's Avatar
I use 91 CRX Si brake pads wth a minor amount of backplate edge grinding - not on length - and since the CRX has a wide range of brake options I recommend them. I use Hawk Street/trank pads to excellent use on track at VIR and the street.
Old Feb 26, 2008 | 06:01 PM
mahout's Avatar
If you do serious braking the 91 CRX Si pads from Hawk and Performance Friction will fit with only a minimum of backplate grinding - none on pad - and are a tad short but you still get half deep in the upper 'notch' so heat expansion is good. we've put in 20 minutes worth of race track speeds with nothing but excellent braking from 100 mph repeatedly.
Better yet there is a complete range of performance pads available for the 91 CRX Si so you choose what you need. Prices are good too.
Old Feb 26, 2008 | 06:48 PM
SHG_Mike's Avatar
BASE Rsx pads are a DIRECT fit. They are the same calipers
Old Feb 26, 2008 | 08:34 PM
Mr.Ball's Avatar
Just be careful with some aftermarket pad's.Sometime's they only(or just work better)with an upgraded rotor package.Good Luck.
Old Feb 26, 2008 | 09:02 PM
SHG_Mike's Avatar
^^^^ what pads are you refering too? Many Honda Challenge teams (race cars) use autozone rotors
Old Feb 26, 2008 | 09:15 PM
Mr.Ball's Avatar
I had an experience with my old Integra were I bought some aftermarket pad's and went to get them installed and a tech said I should upgrade with some rotor's because most aftermarket pad's run a harder compound and there will be a loud griding on the stock rotor's.I ended up reading in a magazine or something of other people experiencing the griding also.Just something to consider.
Old Feb 27, 2008 | 12:28 AM
SHG_Mike's Avatar
just a word of advice dont believe everything you hear or read
Old Feb 27, 2008 | 11:15 AM
Mr.Ball's Avatar
It's your money.
Old Mar 9, 2008 | 07:39 PM
mahout's Avatar
Perhaps they may be the same but they didn't fit my Fit: too thick. And the length of 136.6 mm was a bit long tho they can be easily ground off. However, reducing thickness is a major problem as you would need a good surface grinder to yield a nice smooth straight surface. Grinding a little off the backplate is pretty easily done with a hand grinder - or even a hand file tho it might be more than the grinder's 15 minutes for all 4 pads. Hawk HPS pads work very well on the race track especially at the limits of a Fit.
And the cost is economical.
harlen
Apr 24, 2011 05:42 PM
TWGE08
Apr 5, 2010 11:20 AM
mikejet
Sep 12, 2009 11:12 PM
Amageus
Feb 7, 2008 06:36 PM
Nino NoSpam
Aug 11, 2005 09:30 PM
