spring and shock combo install..NEed HElp!
Old Jan 26, 2010 | 11:35 AM
SD_MR_FIT's Avatar
alright so i took out my driver side, and i cant seem to replace the new t1r and spring.
i tried springs compressors but that doesnt help
the shock mounting points seem to be to low and i cant drop the hub or else the axle will pop out. then i guess ill have more problems to deal with.
how did yall mount them up? i have taken this out like 4 times and this is the first time i have ever encountered any problems.
if you had the same problem and or you know what to do. please give me a call at 858-774-7442
ill be outside trying to figure this out.
thanks.
Old Jan 26, 2010 | 12:50 PM
danger69's Avatar
Even for my coilovers I had to get it aligned with the hub correctly for it to kinda slide in. Do you have the wheel turned all the way to the left. I had to finagle the shocks a bit myself to get them out of the car. When I removed the stock shock I just rested my hydrolic jack under the hub so it doesn't move. That gave me some room to play.
Old Jan 26, 2010 | 01:27 PM
macbuddy's Avatar
...disconnected the swaybar already?
SD_MR_FIT,
Did you disconnect the front swaybar? If not, then that might be why you are having trouble getting enough room to work with.
-macbuddy-
Old Jan 26, 2010 | 02:45 PM
SD_MR_FIT's Avatar
thanks man. i got it to work.
i sat there and your right it was the sway bar.
i just lifted the other side to be even and that helped out alot. i cant believe i didnt think about that before.
apexanimal
Jan 12, 2011 10:17 PM
Lightarrow
Nov 7, 2009 10:05 AM
Lek
Sep 17, 2009 12:18 PM
AWDturbo
Oct 27, 2008 04:00 AM
Mines13
Mar 6, 2007 09:13 PM
