Making my own rear disc coversion
Old May 9, 2014 | 10:15 AM
demouser's Avatar
Yea, I looked at the floor pan and rear brace images. Agree, totally different.
I see the Insight rear suspension is similar to the Fit, but it too has drum brakes.
Old May 9, 2014 | 11:59 PM
Rollerboots666's Avatar
Just going to throw on some Ferrari carbon rear disc's and call it a day. So what if they're worth more then the car. BALLA! hahaha
Old May 10, 2014 | 12:48 AM
13fit's Avatar
honestly guys, the easiest way for rear brakes without using aftermarket parts is to buy a crz rear axle and brake lines, and swap your front hubs to the crz hubs.
They go right on, and then you grab a set of 5x114.3 rims and you are good to go.
Also new ebrake lines for crz most likely
Old May 10, 2014 | 02:25 AM
Ahhh I'll stay with the 4x100 with the Volks. Besides Having a good front brake setup will be sufficient enough for most unless you're pushing a k swap or boost setup.
Old May 14, 2015 | 11:51 AM
Jaime Gonzo's Avatar
Fastbrakes Del Sol spindle inquiry
I contacted Fastbrakes this week. I was trying to purchase only the bracket (spindle, knuckle thing...no lines, caliper, rotor). I thought the kit used Del Sol spindles but it seems not. Here is my question to them and the reply I received.
Question:
I would like to purchase a pair of, not sure on the name, 2008 Honda Fit rear spindle/knuckle and bolts. I think the kit you offer came with Del Sol rear spindles/knuckles. I would only like the spindles/knuckles and bolts only and not the entire kit. Please let me know what I should do to purchase these parts?
the Product Code is: FASTBRAKES FIT REAR DISC SWAP
http://www.fastbrakes.com/ProductDet...+swap&CartID=1
Reply:
I’m sorry but we no longer have the parts needed to swap the Fit to rear discs. The kit used a custom bracket to locate the calipers; it was not a swap using del Sol rear spindles, those are a completely different type of set up.
What do you guys think? I am trying to learn more about the rear drum to disc conversion.
Old May 14, 2015 | 12:18 PM
1SickVeilsideZ's Avatar
As his response mentions, they use a bracket that goes in between. You don't need to replace the whole spindle. Look up apexanimals thread and DYI, plenty of good info.
Old May 14, 2015 | 09:11 PM
apexanimal's Avatar
we've done this now...
go buy some parts: apexanimal's DIY Rear Disc Conversion Thread
apexanimal
88
Apr 18, 2023 12:52 PM
taFITta_sport
Jun 25, 2010 12:52 AM
FIFE
Feb 3, 2010 03:53 PM
porkiporki
May 14, 2008 08:24 PM
Deivioncrx
Jan 9, 2007 03:15 AM
