WHAT DO YOU THINK? posts looking for others opinions
Old May 28, 2007 | 02:31 PM
  #401
ride_the_pony69's Avatar
Looks like you have rotas, why can't you just tell me what you think?
Old May 28, 2007 | 02:35 PM
  #402
H8TON's Avatar
Either way old or new post.I would go with the 16" with the 205-45-16 and as far as running issues I have none!! sitting low on Megan Racing coilovers!!!
Old May 28, 2007 | 03:25 PM
  #403
JDMish's Avatar
Yes I have rota's on the fit, they 16x7 with 195/50 rubber. they rub on hard corners or with 2 or more people in the car. I cant understand people saying that have zero rubbing issues because, they must weigh 100lbs and only drive by themselves...
Old May 28, 2007 | 03:28 PM
  #404
H8TON's Avatar
Ya as far as rubbing I have no issues and from the pic you can see just how low the car is sitting. I thing maybe if I loosen up the dampening on the coilovers the car would have more roll and then rubb and thats from living in the mountains and really curvy roads!~
Old May 28, 2007 | 03:31 PM
  #405
George02's Avatar
16x7 I have it dropped and theres no problem with rubbing, and theyre a perfect fit, for tires im using 205/45/16
Old May 28, 2007 | 11:16 PM
  #406
grandam's Avatar
need rim size advice
I am just wondering what you guy's think looks best on a honda fit lowered I am looking at getting some rims in either 15",16",17" also the car is lowered 1.8"
Old May 28, 2007 | 11:33 PM
  #407
radareclipse's Avatar
Fifteens will have the best ride quality. Seventeens will look def. Sixteen will result somewhere in between. The larger the wheel, the more you have to pay attention to offset and the pickings get slim to choose from.
Old May 28, 2007 | 11:58 PM
  #408
grandam's Avatar
and what offset do I use on these cars
Old May 29, 2007 | 02:38 AM
  #409
going with rota circuit 8 in gunmetal.
Old May 29, 2007 | 07:16 AM
  #410
Some will say a little different, but at least 45mm for a 16 inch and your safe. Seventeen, I'm not sure but I would say even more.
The stock 15 inch wheel has a 55mm offset. The lower the number, chances are it will rub the fender/quarter panel.
There are wheel companies that say their wheel will work when in fact they haven't tried it themselves. Do your searching under the "Fit Shoes" part of the forums and good luck.
Old May 30, 2007 | 01:40 AM
  #411
DMC's Avatar
DMC
IForged-custom built wheels:
Hey all,
I have been racking my brain for the last 2-weeks trying to figure out what wheels to get for my Fit! I recently took delivery of my Sport model(auto/tw) on Mothers Day, and absolutely love this car. I'm looking into having a set of custom built wheels made from IForged. iForged Performance Wheels - The next generation in forging technology
Anyways, Vince at IForged said that I can have a set of 17x7's made to fit the Fit. My question is, what offsets would be ideal for front and rear? I mean, if these wheels are going to be custom built to my specs, I was hoping some of you could tell me what would be the best set-up. Let me also mention that I do plan on running the Tanabe DF210 springs(possibly the GF210 as well-but still wanting the lower look). I have heard that a +42 would probably work for the 17x7, but people were saying that there was rubbing issues as well, mainly in the rear though? So maybe +42 for the fronts, and maybe +38 for the rear? I'm not sure...that's why I need your help, and any help will be much appreciated! Thanks.
Btw, here's a pic of my other vehicle with 22" IForged "Rev" wheels.
Old May 30, 2007 | 02:09 AM
  #412
fits_all's Avatar
that tacoma looks sweet! btw, if youre getting wheels done by your specs, just settle things down on what you want. If you want a lip on your wheels, the lowest offset on a 17x7 should be +42. you still could run lower offsets(deeper lips) but will have to do many mods to not screw up something. If you really dont care about the lip, go crazy and have a +45-+47 offset so no rubbing occurs while dropped. Although, lower offsets do not mean more "deep dish" wheels, but a crazy style that has the spoke design close to the center of the wheel. +38 17'' in the rear will rub, if you dont roll the fenders.
Old May 30, 2007 | 04:10 AM
  #413
DMC's Avatar
DMC
I appreciate the info! Yeah...I definitely love, and prefer the looks of a "deep dish", but obviously on this car, I dont think that there is going to much of one. I would also love to run a staggered set-up, but once again, don't know if that's going to be possible without any rubbing issues. Basically what I want to do is: Lower the car, throw the wheels and tires on(with the biggest lip possible), and not really have to modify a lot to make sure things don't rub(Hence the reason for finding the perfect offset). I don't have any problems with rolling the fenders, so if I have to do that, I will. Do you think that the rear wheels should have the same offset as the fronts? I'm just trying to find the "happy medium" between a sweet set of wheels with as much lip as possible, and not a lot of rubbing issues by doing so. I'm also thinking about picking up a set of Gram Lights 57 maximum, if I decide not to go with the IForged. I know that there's really no lip on these, but I like the way they look as well.
Thanks again!
Old May 30, 2007 | 09:07 PM
  #414
bunline's Avatar
hi guys im new to the site, jus waitin until september for my fit to arrive also in the market for rims a friend of mine has 18s on his fit i will ask him if they rub and then post response.
Luis
Old May 31, 2007 | 01:22 AM
  #415
Gucci's Avatar
need help on picking wheels..
hii i need help on picking wheels....i want light weight wheels......
i have a several that i might be interested..i think i will go with 15"...
Enkei RPF1
or
Gram Light 57
or
SSR Com C
any other sugesstions??BTW i drive a black fit...
Old May 31, 2007 | 01:24 AM
  #416
fung88's Avatar
Get the SSR Comp. they look hottt
Old Jun 5, 2007 | 02:59 PM
  #417
bgravesmill's Avatar
GT3's tire size
nevermind, thread gone
Old Jun 6, 2007 | 06:04 PM
  #418
FitVing's Avatar
Damn, I've gotta say that is one of the sickest Tacomas I've ever seen. Actually, it IS the sickest one I've ever seen. Nothing like that around this area. NICELY done.
Old Jun 6, 2007 | 06:36 PM
  #419
DMC's Avatar
DMC
Thanks bro! I appreciate the nice words.
Old Jun 9, 2007 | 10:27 AM
  #420
Chingwa's Avatar
Whoa! Imagine your Fit riding on these!
Check em out, airless tires....
Next Gen Tires About To Hit The Road - Airless
