The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
Old Oct 1, 2014 | 07:46 PM
  #1421
15BlkPrl's Avatar
Different angle...
Old Oct 22, 2014 | 09:25 AM
  #1422
cnordt24's Avatar
Wheel: Konig Feather
Offset: +38
Color: Black
Tire: Hankook Ventus V2 Concept 2
Lowered?: yes
If Yes, What Setup?: Eibach pro kit
Front Rubbing: Only if I hit a bump at high speeds and it is minimal
Rear Rubbing: No
Comments: I didn't need to adjust anything, I don't get any rubbing while turning or cruising around town. I get a tiny bit of rub if I'm flying down the highway and I hit any kind of dip in the pavement, but it's minimal.
Old Nov 16, 2014 | 11:42 AM
  #1423
Fitguy07's Avatar
Had these installed a couple days ago. Enkei RPF1s, Bright Silver, 15x7, +41 offset, Muteki SR48 Black Lugnuts. Mounted on Kumho Ecsta 4Xs, 195/55/15s which I had the stocks on previously. Total weight at each corner is 27 lbs down from 35 lbs. The stance is much better as the wheels pushed further out fill the wheel well nicely.
This is the first set of lightweight rims I've owned on any car. Biggest difference to me is the braking by far, followed by handling then acceleration. The ride is more comfortable than stock and more sensitive as well. In the spring I want to clean up the rust on the calipers and rotors. A slight drop and some tire dressup will do wonders to the overall look being I have thicker sidewalls.
Shout out to Spencer at the Bean Garage for the purchase and awesome communication back when I bought these in August.
Old Nov 21, 2014 | 01:49 PM
  #1424
FitMinister's Avatar
New Shoes!!! YAHOO! Thanks to Sickveilside for all the help.
Old Nov 24, 2014 | 02:08 AM
  #1425
555sexydrive's Avatar
Fit center bore is 56.1mm. Not going to read through all 8 pages, but I saw the first post still shows question marks.
Old Feb 9, 2015 | 03:09 PM
  #1426
Alvarooo90's Avatar
Wheel: F1R F03
Offset: +25
Color: polish
Tire: Continental
Lowered?: Yes
If Yes, What Setup?: Function & Form Type II's
lugs: Extended no brand steel lugs
Front Rubbing: no
Rear Rubbing: no
Fender mods: yes rolled and pulled.
Old Feb 9, 2015 | 03:10 PM
  #1427
Alvarooo90's Avatar
Wheel: F1R F03
Offset: +25
Color: polish
Tire: Continental
Lowered?: Yes
Front Rubbing: no
Rear Rubbing: no
Old Feb 10, 2015 | 06:30 AM
  #1428
Black3sr's Avatar
Originally Posted by Alvarooo90
Wheel: F1R F03
Offset: +25
Color: polish
Tire: Continental
Lowered?: Yes
Front Rubbing: no
Rear Rubbing: no
That is plain nice. Well done.
Old Apr 28, 2015 | 12:12 PM
  #1429
K. Grobinski's Avatar
2015 GK EX/MT
16x7 40 offset Rage R10
195/55R16 General GMAX AS-03
$708 mt/balance/shp w/repl -DiscountTireDirect
These shoes really feel great. Nice ride quality and confident grip, really quiet. IMO they fill the wheel wells out a bit better than the 185 stock size and the tread pattern looks legit.
Terrible pics, stay tuned... Need to do something about the bare alum on the extra lug holes.
Old Apr 30, 2015 | 12:24 PM
  #1430
bellzGD3's Avatar
Spring is back
Ig:abellp
Old Apr 30, 2015 | 04:34 PM
  #1431
BlueBeard's Avatar
New look for the RPF1's...
I had some new rubber installed recently and the tire shop chewed up the finish on one of my wheels so...since they were paying to re-powdercoat the one I figured I might as well do 'em all. I had the original Enkei valve stem caps and my DIY center caps sprayed to match.
goodbye candy blue...hello illusion purple
Old May 2, 2015 | 12:00 AM
  #1432
fr8train's Avatar
Anzio Vision
Offset: 45mm
Backspacing: 5.039"
Bolt Pattern: 4-100
Rec. Tire Size: 195/55-15
Weight: 15.8lbs.
Finish: Matte Graphite Silver
Old Jul 29, 2015 | 05:44 PM
  #1433
neoecks's Avatar
Very nice!
Old Jul 29, 2015 | 05:50 PM
  #1434
neoecks's Avatar
this is a good vip look too!
Old Jul 29, 2015 | 06:03 PM
  #1435
neoecks's Avatar
too bad alot of these pictures are not available for viewing.
Old Sep 23, 2015 | 10:22 PM
  #1436
snail_power's Avatar
Just got done with a round of small mods. pretty excited about how it turned out so far. (dirty and 150k miles in the photo tho. :P )
Old Sep 25, 2015 | 01:39 PM
  #1437
Hootie's Avatar
I forgot about this thread.
Wheel: Avanti Storm S1
Size: 15x9 front, 15x7 rear
Offset: +35
Color: Hyper Silver
Tire: Nitto NT01 front, Toyo R888 rear
Size: 225/45R15 front, 205/50R15 rear
Lowered?: Yes
If Yes, What Setup?: Ground Control sleeves, Eibach springs, & Tokico HTS
Lugs: NRG 100 series
Front Rubbing: No
Rear Rubbing: No
Fender mods: Nope
Old Sep 25, 2015 | 02:26 PM
  #1438
domoMKIV's Avatar
I need more pics of the S1's. I like them but I think I would have to raise the front up a bit which means new suspension. ugh.
Old Sep 29, 2015 | 01:02 AM
  #1439
Alvarooo90's Avatar
New shoes!
Excuse the lack of rear lip, it will be back on soon.
Same specs as before 15x8 +25 wrapped in 195 50 15
Old Sep 29, 2015 | 07:49 PM
  #1440
I realized I didnt give the info on my wheels.
Wheel: Avanti Storm S1 DST
Offset: +35
Color: Matte Grey
Tire: Dunlop Direzza DZ102 SL
Lowered?: Yes
If Yes, What Setup?: F: KYB Excel-G / Progress springs R: Koni STRT (GE Fit) / Progress springs
Lugs: Black Spline drive Gorilla lugs
Front Rubbing: No
Rear Rubbing: yes
Fender mods: remove rear bumper screw, and some filing of inner plastic mount.
On the plus side, I weighed these wheels and tires vs stockers with worn Goodyear Eagle GTs. They were a solid 6-7lbs (!!!) lighter each. Needless to say acceleration has improved drastically.
If I have one complaint about this setup its that I wish the rear suspension was a bit stiffer, some more hardcore springs or Koni yellows would probably be nice. Its good with the progress rear bar, but could be better with some moar stiffness. Also was hoping to get some BFG G force Comp 2s but they were sold out in 195/50/15 when i was buying.
A couple more photos, the first is fully loaded with probably a couple hundred pounds of camping gear in yosemite. some rear rubbing on extreme freeway dips but a blast on mountain road driving even fully loaded.
