TPMS wheels
Old Apr 22, 2008 | 06:02 PM
gmane's Avatar
Unless you definitely want the TPMS i wouldn't be worried.. i changed my rims out and i have not replaced the sensors or installed them on the new setup and i have no issues.. No lights! *knock on wood
Old Jun 19, 2008 | 04:14 PM
Young Roids's Avatar
Originally Posted by mahout
The TPMS units are small 'boxes' that are the inner ends of tire stems so they can be added to aftermarket wheels but expect cost of $50 to 100 PER WHEEL, making the cost almost the same as the wheel. Thats because there are half-dozen makers with half-dozen programming systems specific to the manufacturer-make. Your government's feckless politicians at work.
Most people put a piece of black electrical tape over the TPMS warning lite. So much for "I'm from the gov'ment and I'm here to help you" senario.
Now I am as anti govenernment as the next guy but I like tpms. I think it's very handy to know when you are low on air or flat. Like when you drive over a big pothole and wonder did I just pop my tire? Wonder no more tpms is there to tell you.
Old Jun 19, 2008 | 07:07 PM
ghibli99's Avatar
Good information and links in this thread. Thank you!!
-Mike
Old Jun 20, 2008 | 07:42 AM
mahout's Avatar
Originally Posted by gonang
are there any other wheels that will accommodates the tire pressure monitoring system other than the stock set? If so, are there any in bigger sizes (such as 17's or even 18's). Or for everyone who's already changed there wheels, how do you disable the system so you don't get the annoying light on the dash.
All wheels will accomodate TPMS devices. Note they cost $50 to 100 per wheel. And since the gov'm't approved 6 different manufacturers you have a low chance of getting the next set to work. Without dealer reprogramming.
Most of us just tape over the warning blinker.
Old Jun 23, 2008 | 08:01 AM
WiggumS2K's Avatar
To the tech that says this information is not accurate, I guess you have never attempted to rotate tires on an S2000 due to a blow out...
Also, my biggest gripe with TPMS is weight, they add .5 LB of rotational mass where it hurts, and the weights needed to balance the tire on the other side add another .5 LB. We spend time nit-picking weights on wheels, and then add a pound, kind of dumb.
Rampo
Feb 1, 2019 05:27 AM
Bogs2013
Jun 11, 2013 12:47 PM
Tk3
Oct 5, 2012 05:37 AM
RipItFit
Aug 11, 2009 12:11 PM
Bustov
Feb 25, 2009 01:40 PM
