16 X 7 48 offset with 205-45-16 will it rub????
im looking to get some 16 X 7 with 48 offset and run a 205-45-16 is that too wide for stock ride height??? will it rub??? and what if later down the road i decide to lower it an inch. should i get a smaller size tire let me get some opinons on this. im new to this guys thanks
holy shit. search. there's a thread about what will, and will not work.
i have 16x7 rims. 38 offset, 205x45x16 tires. lowered on skunk2's adn only rub a little in tight turns and big bumps. you shouldn't have any trouble with that setup you want.
no issues with rubbing in the back WHATSOEVER. idk how someone would have an issue with that. *shrugs*.
ive even transported 30 cases *that's 24 per case* of rockstars. and NO issues in the back
