TPMS Info
Old Apr 12, 2011 | 11:48 PM
  #41
notorious.dds's Avatar
This was mentioned earlier in the thread. At any rate, you might be able to solve your problem with these sensors:
http://www.orange-electronic.com/eng...0Website-R.pdf
It appears that you can program these sensors to match the unique ID's of your current sensors such that when you swap the wheels, your car's ECU doesn't know the difference.
Originally Posted by jibberjabbs
I am looking into ways to simulate a tmps sensor or a tpms receiver allowing me to swap wheels whenever I want and never having to go to the dealer. I realize I am not doing things the easiest way but I really hate the way honda has implemented this federal mandate.
Old Apr 13, 2011 | 12:06 AM
  #42
Anyone else have the issue of all of their TPMS sensors going bad? I had one go bad just before the warranty expired at 36,000 miles. It was repaired under warranty and then shortly after that (~40,000 miles) the light came back on. My dealer informed me that the other 3 sensors were no longer working. They said that they could replace them for $60 each. I told them that if all I can expect to get is 40,000 miles before they all die again, I don't need them. The sales rep then stated that they don't typically see this issue on any of their other cars and that the sensors should last 100,000+ miles. I asked how long the repair would be warrantied if I got the bad sensors replaced. She said 12,000 miles.
My TPMS system light is still on.
Old Dec 5, 2013 | 08:02 PM
  #43
rickpaulos's Avatar
I got it figured out. TPMS = Traffic Pattern Monitoring System. Each of the 4 sensors broadcasts its own unique serial number to a receiver somewhere in the car to light up the idiot light on the dash or feed more data to the traction control (if your car has that too) According to other info I found on the www, the sensors signal can reach up to 100 feet. Of course your car computer needs to recognize its own tires and not get confused by other signals in traffic, hence the code registration by the dealer for $100. BTW, the codes have to be done in proper order so the traction control knows which wheel/tire is slipping.
Eddy Snowdenn hasn't yet released the papers that say the gubermint has secret tpms receivers
installed all over the place as another means of tracking our whereabouts. At customs, toll booths, those highway cams that measure traffic speed, bridges that have those surface conditions monitors, etc. You can bet the spooks have the tpms codes (from the dealer info) matched to the vin numbers matched to your state's dot records.
Thank you, thank you. Elvis has left the building.
Old Dec 5, 2013 | 09:15 PM
  #44
BraytonAK's Avatar
hahaha! A great first contribution to the forum.
Old Dec 5, 2013 | 09:46 PM
  #45
xxryu139xx's Avatar
Haldol cocktail anyone?
Old Dec 6, 2013 | 03:04 PM
  #46
MNfit's Avatar
Originally Posted by rickpaulos
a lot of jibrish and tinfoil hat ideas
What exactly are you going on about?
Old Dec 6, 2013 | 04:25 PM
  #47
Wanderer.'s Avatar
RIP
Old Oct 26, 2015 | 03:41 PM
  #48
glockprime's Avatar
Originally Posted by JCLW
I thought that when the TPMS light was on, VSA was stuck on (for those vehicles where you can turn it on & off).
Correct. I don't care for TPMS, but I need to be able to turn off traction control. Anyone know how to get rid of both?
Old Oct 26, 2015 | 04:13 PM
  #49
jibberjabbs's Avatar
You can unplug the vsa diable button and force a fault that will disable the TC and VSA. You have to drive for about 2 minutes before the fault will be detected. To undo just plug the button back in and restart the car.
Old Apr 29, 2020 | 02:56 AM
  #50
Stringle_Dingle's Avatar
In my 2013 Base Model US Fit the TPMS Light has been stuck on, but when a tire is low the low tire light is displayed instead. The only thing about this that is upsetting is that I cant turn traction control off while the TPMS is throwing its fit.
fritz269
Jul 21, 2016 12:16 AM
HermTDI
Mar 17, 2015 08:06 AM
Wolfvision
Apr 16, 2010 04:14 PM
Bustov
Feb 25, 2009 01:40 PM
strmslvrfit
Nov 5, 2008 01:42 AM
