Enkei vs Vaarstoen 16x8 vs 16x7
Old Jun 17, 2012 | 03:59 PM
  #41
krunk13's Avatar
I hope you are just kidding.
Lol its simple math man....
6.5" at 53mm= stock
7.0" at 45mm= 2mm MORE Inner clearance and EXTEND an extra 14mm
6.5" at 38mm= 15mm MORE Inner clearance and EXTEND an extra 15mm
....Soooo really its only 1mm extra
Old Jun 17, 2012 | 11:25 PM
  #42
Texas Coyote's Avatar
The math makes sense. I had 16"x7" 38mm with 195-50-16s with stock springs that would scrape the front fender when cornering and in the back and front on bumps... I would imagine that if I had problems with that setup on a GD3 there would be a problem with 205-50-16s on 16x6.5 on a GE since that is the tire size that has been mentioned the most...
Old Jun 17, 2012 | 11:32 PM
  #43
krunk13's Avatar
No you have to take in to account the size of the wheel too. Running a thinner wheel lets you run lower offset wheels.
Old Jun 18, 2012 | 12:25 AM
  #44
That is quite obvious to anyone and hasn't been disputed...
Old Jun 18, 2012 | 04:37 AM
  #45
krunk13's Avatar
lol you just said you couldnt run a 38 mm offset on a 6.5in rim
Old Jun 18, 2012 | 04:53 AM
  #46
spootnik's Avatar
Last question
Now that i am 99% decided on +45mm, rubbing being a non issue.
I have asked the same question to Goobers in another thread, he hasn't replied in a while, so i thought i'd ask here if someone picks it up.
I am almost there ..... can't wait to take a 6hr trip in that car once i get this done.
What springs or measurements will give me the 1 finger gap front and back or a 2 finger gap rear.
I'm thinking eibachs so far .... they are F1.2" R1.4"
Also contemplating Teins F1.6" R1.6"
Old Jun 18, 2012 | 05:00 AM
  #47
krunk13's Avatar
Old Jun 18, 2012 | 05:46 AM
  #48
spootnik's Avatar
I'm in Canberra, roads are pretty awesome quite honestly. Except for the occasional rainy days when the road gets some nasty holes and when my wife drives right into one, i can't help but imagine if those were 17" low profiles "Baaang" $$$$$$.
Hey, i was talking to a guy from JDM and they sell Teins and eibachs. I don't get it, on ebay they are 1.2" 1.4" but from JDM they are 1" 1.5". Why do they differ so much ???. The 1.5" R might lower the rear more than the front ? maybe.
Old Jun 18, 2012 | 05:59 AM
  #49
krunk13's Avatar
Id just look at the part numbers on the manufactures web site and go by that.
Old Jun 18, 2012 | 06:06 AM
  #50
spootnik's Avatar
These s tech ok with stock shocks ?
Old Jun 18, 2012 | 06:26 AM
  #51
krunk13's Avatar
Well they kinda have to be. No one makes shocks for the GE8.
Old Jun 18, 2012 | 06:34 AM
  #52
spootnik's Avatar
So, Goobers who has the exact same settings as you and me described
205/50/16 +43 offset with 1.2"F 1.0"R and he rubs
Now, my question is .... you don't mind the occasional rubbing ? or you will adjust camber ?? or you believe it won't rub for you ?
Old Jun 18, 2012 | 06:35 AM
  #53
spootnik's Avatar
Goober is also running RPF01
Old Jun 18, 2012 | 06:45 AM
  #54
krunk13's Avatar
Well on my E30 BMW I rub on hard bumps and it really isn't that bad. As long as your not rubbing regularly and damaging your tires i wouldn't worry about it. Camber bolts are cheap insurance against rubbing though. Definitely install them if your going for s. Techs.
Old Jun 18, 2012 | 06:58 AM
  #55
spootnik's Avatar
Ok, now am gonna step into the unknown.
What are those camber bolts , how much they cost and fitting and how do they prevent this 2mm rub ?
Won't go s tech, been reading around and with stoke struts i rather stick with something mild. I'll consider lower after the struts are worn out and googling tein vs eibachs was like a 10:4 ratio in favor of eibachs when it comes to springs.
Old Jun 18, 2012 | 07:12 AM
  #56
krunk13's Avatar
Camber bolts are used to induce positive or negative camber (you need negative).
Eibach Recommended Align. Kit
They cost $26
Old Jun 18, 2012 | 07:15 AM
  #57
spootnik's Avatar
Then out of nowhere you read something like this:
"Before I got the 15x7's I was running 16x7 +38 205/50 and would only rub fully loaded, this combo still works just need to be careful not to take tight corners too fast, but whats the fun in that!"
He was +38 and only rubbed fully loaded ....... geez, so many different feedbacks it's confoosing
Old Jun 18, 2012 | 07:30 AM
  #58
krunk13's Avatar
Go with the majority. Most people have little to no trouble with 43-45.
Old Jun 18, 2012 | 07:41 AM
  #59
spootnik's Avatar
They cost $26
Not a big deal at all . I thought this was gonna cost hundreds and requires some serious tweaking. Not bad at all .... Good to know.
Old Jun 18, 2012 | 07:45 AM
  #60
spootnik's Avatar
Now i'm considering the +43 again If ever it rubs, then i'll get those camber bolts. Hmmmmmm, everytime i seem to come close to a decision, something comes in the way
Good learning curve. Thanks again for the help bro, really appreciate it.
