GD3 - Help me pick the correct offset for Enkei RFP1 16x7
Old Jul 15, 2012 | 07:08 PM
waramp's Avatar
Hi fellow Fit Freaks,
I've been reading through a bunch of posts and haven't seen a compelling enough answer so I created this thread.
I have a GD3 on stock springs and want to replace my worn out stock rims/tires with Enkei RFP1 16x7.
I'm wanting to have a nice flush look without rubbing. I would like to know first hand from owners what spings/offset/tires you're running? This is a DD and I'm not looking for that "hella flush" slammed look
Old Jul 15, 2012 | 07:23 PM
Optimal fitment on a GD (IMO) is around a 7j +35-38 up front and a 7j +25-28 in back
Old Jul 15, 2012 | 07:24 PM
waramp's Avatar
Thanks Mike
Old Jul 15, 2012 | 07:46 PM
JDMchris.com's Avatar
I run THIS
it depends on tires/drop. Stock height it doesn't matter much. If you are lowered on springs you will rub on hard turns no matter what. The RPF1 in 16x7 4x100 only comes in +35 or +43. Go with the +43 205/45/16 tires. and you should be good stock or lowered.
Old Jul 15, 2012 | 07:50 PM
He'd be good stock/lowered on both offsets.
Old Jul 15, 2012 | 08:28 PM
I run THIS
the +35 will rub significantly unless he starts rolling fenders stretching tires or adding camber. I've already run the offset. it will rub lowered on springs and on hard turns with coilovers.
Old Jul 15, 2012 | 08:43 PM
My 7j +37 RARELY rubbed on Tein Springs.
Old Jul 15, 2012 | 09:27 PM
waramp's Avatar
Thanks JDMchris!
Old Jul 15, 2012 | 09:30 PM
waramp's Avatar
I think i'm leaning towards the +43 205/45/16 tires unless someone can show me some good picture comparisons. I'm fine with throwing some springs on for my DD if that will help get me that nice clean look i'm going for.
Thanks for all your help!
OrganicFit
13
Dec 16, 2014 07:45 AM
SiRca90
Feb 26, 2014 07:39 PM
SoFit
Sep 28, 2011 01:12 AM
lungfish23
For Sale - Local Pickup Only
Sep 23, 2010 08:02 PM
HB1320
Apr 29, 2009 01:49 PM
