Weapon*R Intake Manifold!
Old Apr 24, 2008 | 04:03 AM
  #141
claymore's Avatar
I ran mine with the EGR unbolted from the block, the hole in the block plugged with a plate, and the EGR bolted with a bracket above the header behind the intake manifold (so you can't see it) open to the air. Works fine and no MIL and if you play with them awhile to find the right FIT the stock wires have enough length you don't even have to add more wire to the stock ones. If you want to try it just clear your MIL then plug the EGR back into the original wires and just let it hang loose behind the intake and see if it works for you.
Old Apr 24, 2008 | 09:31 AM
  #142
Kuturagi's Avatar
Do you who have it have any fitment problems like the WR header? How hard was it to install and what issues did you have, or was it a literal bolt and play process?
Old Apr 24, 2008 | 10:31 AM
  #143
Sugarphreak's Avatar
Push My Button
Good info, I will try this out. Thanks!
Pretty much just bolt it up, no major fitment issue. however play only after you tune.
Old Apr 24, 2008 | 11:41 AM
  #144
Kuturagi's Avatar
and how much is a tune normally? Also, where do you go to get those, I'm here in Iowa in the midwest so where would I be looking?
Old Apr 24, 2008 | 12:21 PM
  #145
Push My Button
I think you can get the optional 50$ "fuel computer" from Weapon R which won't need a tune.
If you want to get your car tuned, the best option (at least from what I know) is the Greddy E-manage Ultimate. AJR has a tune map for my car (Manifold plus I/H/E) you could contact them about. They might also be able to hook you up with a harness for the system.
Other options would be the Apexi Neo.
You would have to call up your local tune shop to find out rates for install and tune.
Old Apr 28, 2008 | 04:22 PM
  #146
smirff07's Avatar
im dumb couldnt find anything on WR page about pre order or fuel management? what do they use for fuel manage that is only $50?
Old Apr 29, 2008 | 03:09 AM
  #147
Tofuman's Avatar
waiting for an answer from Weapon*R regarding the EGR issue.
Old May 7, 2008 | 12:45 PM
  #148
WRLEO's Avatar
Working on the EGR issue.. didnt have problems working on the cars in Asia.. Might be a USA / Asia difference in the EGR's..
Old May 19, 2008 | 11:56 AM
  #149
claymore's Avatar
Originally Posted by WRLEO
FYI the honda fit doesnt have deflectors in the plenum... I studied the flow of the Stock IM before we designed this one.. The stock one is a LOG which feeds the cylinders..
I knew I saw them somewhere and here they are cut away phots showing the deflector inside the stock manifold. Showing that it is NOT just a log manifold. See for yourselves.
"borrowed" from temple of Vtec Asia
EVEN BETTER
One more for the unbelievers....
Old May 19, 2008 | 12:03 PM
  #150
Push My Button
Just an update, we are trying to get the software for the Greddy E-Manage right now so we can cancel out the CEL.
Hey Claymore, that stock manifold looks different then mine. Maybe I will snap some pics of mine later today and post them up here.
Old May 19, 2008 | 12:35 PM
  #151
Kuturagi's Avatar
isnt that manni off the JDM one?
Old May 19, 2008 | 01:39 PM
  #152
Push My Button
Ok, here are the comparo pics... first a few of the stock manifold inside:
Here are the pics of the stock EGR location and what is causing the CEL
Now, here is the Weapon R Intake pics with the new EGR routing:
This picture shows where the old one is blocked, it should be between these two runners.
Old May 19, 2008 | 02:02 PM
  #153
Tofuman's Avatar
so even with the EGR fix, it still throws a CEL?
Old May 19, 2008 | 04:47 PM
  #154
Push My Button
Right now it is, because the original EGR is still blocked. As soon as I get my hands on that software we are going to try to override it.
I wonder how hard it would be to tap in a hole and screw a nipple for the EGR tube on that?
Old Jun 3, 2008 | 05:11 PM
  #155
Push My Button
Appears I may have jumped the gun on this solution, I don't think E-manage can do this.
Hey Claymore,
Any chance you could snap a few pics of this setup when you have some time. Would be greatly appreciated,
Thanks!
Old Jun 3, 2008 | 10:28 PM
  #156
Push My Button
Quick question regarding this fix,
Ok, if I understand this correctly; I pull out the EGR (Red) and block the hole with a plate; then cap off the current EGR routing into the manifold (Green)... then where do I route the new blue EGR tube from the yellow port?? Block it or let it vent freely.
Old Jun 4, 2008 | 01:22 AM
  #157
claymore's Avatar
You have got me confused I think you are confused. First all the EGR is INTERNAL to the head there are no hoses or pipes for the EGR system it's ALL inside the engine. The hose you are talking about is the PCV hose (not 100% sure on the USDM version but 99.9%) and will work just fine where it's mounted.
The fix I did starts like you said take off the EGR, block the old hole then just let the EGR valve hang out in open air any where you want. I unclipped the stock wires and they were long enough to go over the valve cover and mounted the loose EGR on a bracket using the stock bolt into the header shield. Worked for me no MIL.
Just block the hole then with the EGR just stuck somewhere so it doesn't rub on the belt start it up and see if your MIL goes away before going to the trouble of making a bracket.
Old Jun 4, 2008 | 11:02 AM
  #158
Push My Button
I am definitely a bit confused
There is a port between the lower two runnners that is totally blocked off; I think on the overseas version there is no port... don't quote me because I am not sure. The pic below shows where it used to exit through the stock manifold and then into the (now blue) pipe which hooks into the lower location (marked with yellow above). It is my understanding this port is part of the EGR recirculation system and because it is now is blocked off it is causing the CEL to come on.
Old Jun 5, 2008 | 07:39 AM
  #159
romanc333's Avatar
I just installed my intake manifold yesterday
And I got a CEL as well so since you guys are smarter then me you can hash it out and let me know cause im dumb. Ok also this may be a stupid question but I bought the 50 dollar lil fuel computer and it has the toggle switch on it. Well there is no indication on what selection it should be on or what the function of the toggle switch is. Can you answer me that? What position should it be on and why is there 2 positions?
Thanks
Steve
Old Jun 5, 2008 | 10:01 AM
  #160
Fitcapo's Avatar
tagged for intrest in problems etc....
