Apexi Coilovers for GE-8 on a Group Buy ONLY
Old Jul 11, 2011 | 02:29 PM
  #281
SSMTEN's Avatar
Originally Posted by MSILVEST04
I haven't yet was supposeto install this weekend but something came up... Everytime I look at em I feel overwhelmed with setting them up correctly have been reading everything I can on how to correctly set up ride height with out corner balancing em still a little confused I'm sure once I see how everything works ill understand how to do it
just go lowest setting... there is no other option
Old Jul 11, 2011 | 03:49 PM
  #282
j's_fit's Avatar
did anyone adjust their camber after installing suspension??
Old Jul 11, 2011 | 04:59 PM
  #283
howiedoit's Avatar
my rear alignment was still perfect after installing the coilovers. The front was off, so I had an alignment done. But I need to install camber bolts now because of the rubbing. I pulled the front fenders slightly too...
Old Jul 12, 2011 | 01:33 AM
  #284
theindiearmy's Avatar
Rear alignment shouldn't change much, if at all. I have an issue, so I can here the top of the passenger front strut grinding and I know it's because it is popping up, but I've tightened the bolt down as far as I can get it. I don't have this issue with the driver side moving up and down too much, if at all. What's the best way to correct these if tightening the bolt isn't an option? Should I take it to a shop and try an air tool? I never understood how an air tool can tighten the bolt if it can't hold the hex in place at the same time. Any insight? Thanks
Old Jul 12, 2011 | 09:05 AM
  #285
SSMTEN's Avatar
it shouldnt be moving.. how far up is the strut sticking out of the hole up top? shouldnt be very far. we left off a rubber bushing and a hex-nut (from the oem strut) and had the same problem..had to go back and replace. are you sure you used all the hardware?
Old Jul 12, 2011 | 12:21 PM
  #286
I took everything off the stock strut that the manual said to. The strut sticks out about an inch from the rubber on top. When stationary, everything is tight, but when I go over bumps and hop on the frame inside the passenger cabin, it pops out, moving up about half an inch. I've been told an impact gun will tighten it more so I'm going to that soon. If that doesn't work, I'm going to try the stock nuts that don't have the nylon in them.
Old Jul 12, 2011 | 11:02 PM
  #287
MSILVEST04's Avatar
When you go the lowest setting are all three lock rings stacked up on eachother?
Old Jul 13, 2011 | 01:11 AM
  #288
j's_fit's Avatar
oh my god.....my N1 is coming..... hahahahaha =)
soooo happy
Masaki just sold me a set!!!!
of course I didn't get the same price as you guys did!!!
but still very good deal
Friday ..... Friday is the date!!!
Old Jul 13, 2011 | 01:37 AM
  #289
A'PEXi-FIT's Avatar
Correct, there is no way to tighten the bolt on the top side of the body, without having an allen hex in place. There is another nut that can be torqued down to prevent the shock assembly from moving:
Ok, quick fix. On the front damper, there is a factory bushing and a nut (19mm) that needs to be used that holds the upper spring seat mount (included) and spring in place. (note: assembly before putting the factory rubber upper mount on).
An impact may not torque this nut (19mm) down all the way. So take an open 19mm wrench and then take the allen hex to hold the shock into place. If this 19mm nut is not torqued down all the way, this will leave the excess play that will result in not being able to torque down the top nut on the very top side of the body of the car, therefore resulting in the shock moving to move and causing this noise.
See if this fixes the problem.
Masaki @ A'PEXi
Old Jul 13, 2011 | 01:42 AM
  #290
A'PEXi-FIT's Avatar
As SSMTEN noted, the bushing and hex-nut (19mm) from the factory strut needs to be used to make sure the spring is held into place and also to prevent the excess play which will cause movement of the damper.
Old Jul 13, 2011 | 01:47 AM
  #291
A'PEXi-FIT's Avatar
When you go lowest setting in the front all 3 rings are stacked upon one another. The (1) lower spring seat ring, (2) lock nut right beneath the spring seat ring, (3) the lower adjust case lock nut right above the bottom adjustment case.
Old Jul 15, 2011 | 07:52 PM
  #292
j's_fit's Avatar
Awesome my N1 Damper is here......
ill go pick it up tomorrow!!!! YEAH
Old Jul 17, 2011 | 12:10 AM
  #293
j's_fit's Avatar
hahaha
here is mine set of N1
(pls forgive my poor pix quality.... )
M.I.T =( thought they were M.I.J
A Little something from Masaki =)
Old Jul 17, 2011 | 03:22 AM
  #294
angryfit's Avatar
wtf why didnt i get that???? i want!
Old Jul 17, 2011 | 01:16 PM
  #295
j's_fit's Avatar
Because I paid more on the suspension then u guys!!!
Mine price is not the gb price.....hehe
Old Jul 18, 2011 | 12:59 AM
  #296
angryfit's Avatar
Haha well I bought two sets of coils so hook it up
Old Jul 18, 2011 | 02:40 AM
  #297
j's_fit's Avatar
I also brought 2 sets.... hehe =)
GE8 (N1) and G37 (S1)
Old Jul 18, 2011 | 10:03 PM
  #298
j1nNju1c3's Avatar
I only got a lanyard..I thought we were getting license plate frames too o.O
Old Jul 18, 2011 | 10:09 PM
  #299
MSILVEST04's Avatar
^^^^^THIS^^^^^ lol
Old Jul 18, 2011 | 11:34 PM
  #300
j's_fit's Avatar
don't forget guys I pay more for the N1 suspension!!!
I just ask and see if Masaki can give me more.... hehe =)
Since I missed out on the GB
Don't blame Masaki for not giving that to you guys too!!!
aiya....I feel bad now.... I shouldn't have show you guys that toy!!!!
hehe =)
But one thing I can't believe is our suspension is MIT!!!
my brother's S1 is MIJ
aiya
