Lift a fit with Honda HR-V Struts?
Old Aug 23, 2021 | 01:24 AM
buddyolepal's Avatar
was wondering if this is a way to lift a fit and if anyone has done it? the front struts seem to be similar. im not sure but maybe.
Old Aug 23, 2021 | 11:23 AM
Elpapas's Avatar
not sure but give a try let us know
Old Aug 23, 2021 | 09:41 PM
Hootie's Avatar
I've been thinking about that for the last two years but haven't acquired a strut from a HR-V and a GE8 Fit donor verify with... YET.
From what I understand... The RU5/RU6 HR-V is based on the GK chassis and has a similar strut and rear shock design but of course different lengths.
Top mounts directly interchange between the GK and RU chassis going from rough memory. GK and GE suspension is identical in packaging but dampening and spring rates might be a tad different.
Old Aug 24, 2021 | 01:33 PM
elkaku's Avatar
Subscribing to this thread... Since it's turning to be interesting ...😈😈😈
Old Aug 26, 2021 | 01:58 AM
f*ck it you guys i think im just gonna buy some and see how it goes lol
Old Aug 26, 2021 | 03:37 AM
oh wait nvm it seems the bottom of the struts have different bolt positions. the camber might be off or something.
Old Aug 26, 2021 | 09:18 PM
Hootie's Avatar
@buddyolepal Take a gander at this. Stumbled upon it the other night.
https://www.fitfreak.net/forums/2nd-...DviiI-dLbEWBpU
Old Sep 12, 2021 | 09:01 PM
wondering_misfit's Avatar
I just lifted mine two inches in the rear and about 1&1/4 in the front. I used insight springs and spacers. I have been trying some different types of shocks for the rear. But I have been thinking about trying the HR-V front struts with there spindles.
Old Sep 15, 2021 | 07:10 AM
mobby_6kl's Avatar
There are a few threads on this forum about lifting the fit and year IIRC eitehr HR-V or Insight stuff works but I think only on one axle?
The other option, that I went with, are just spacers. I got it from some Russian company, the rear ones just go above the spring instead of the OEM rubber thingie, and the front go inside the strut. I actually didn't get to install them yet but just wanted to point out that this is an option too.
Old Sep 15, 2021 | 09:29 PM
Yeah that is what I went with, I used the Russian company on the front and rear 30mm spacers, the fronts went above the strut on the ones I used. I replaced all four springs with 2011 and 2010 Insight springs with new KYB struts in the front and Bilstein 5100 24-064576 in the rear, they were the closest I could find with the correct travel length and closest valve rating. I posted some pictures in a thread in suspension section. I’m at 28” in the rear at the moment and about 27 in the front.
phoenity
Feb 11, 2026 03:22 AM
shawnshank
Mar 30, 2018 05:34 PM
The Doge
May 27, 2011 12:11 PM
phasfit
Nov 2, 2008 11:29 AM
kkim
13
Dec 10, 2007 03:28 PM
