Grounding bracket???
Old Oct 12, 2021 | 07:40 PM
TheKangarooman's Avatar
Hello all,
Just pulled the engine on my 2007 Honda Fit for a quick rebuild. Upon reinstallation, I had this (what appears to be) grounding bracket left over. The fires up and runs just fine, albeit with a P0172 error code. Just wondering where it goes.
Thanks,
Matt
Old Oct 13, 2021 | 11:07 AM
Elpapas's Avatar
Originally Posted by TheKangarooman
Hello all,
Thanks,
Matt
looks like your transmission ground
Old Oct 13, 2021 | 01:53 PM
Any idea where on the trans it mounts/bolts to? Is it the top, bottom, perhaps front side? Then, I assume the ground strap would bolt to the driver's side frame rail.
Old Oct 13, 2021 | 02:27 PM
Elpapas's Avatar
[QUOTE=TheKangarooman;1464331]Any idea where on the trans it mounts/bolts to? Is it the top, bottom, perhaps front side? Then, I assume the ground strap would bolt to the driver's side frame rail.[/QUOTE
it should be on top of the trans the bracket on the rail and the small end to the transmission with 10 mil screws
georgi6
Apr 23, 2019 07:49 PM
Arthur33
Jun 12, 2018 07:10 AM
Yummy Flaquito
Zeta Products.net
Jun 22, 2012 09:22 AM
super_mario86
Mar 14, 2012 05:08 PM
Fitlooker
Apr 21, 2010 05:58 PM
