Advice: screeching noise
Old Mar 3, 2022 | 01:45 PM
temoc's Avatar
Hi. A screeching noise occurs when starting the engine. It is as if I'm cranking the ignition too far, but that's not the case. It doesn't happen with a full gas tank, or if the engine is hot. A mechanic told me this is a common problem with Fits, and recommended taking it to the Honda dealer. But as the Honda people couldn't duplicate the noise, that didn't help.
2008 170k miles
Old Mar 3, 2022 | 02:51 PM
steve37's Avatar
Mine has been doing that for three years now. I start hearing it in the late fall when the overnight temps are around freezing. In the late spring..it disappears.
If I bump the starter with a quick on-off of the key first....It won't screech.
Old Mar 3, 2022 | 04:38 PM
Frenzal's Avatar
Maybe your starter is sticking. Common problem on S2000. Didn't think it as common on the Fit.
I hate it when it does it on my S2000. Happens only if the car is cold, never if I start it after some driving.
Old Mar 6, 2022 | 10:21 PM
Dduelin's Avatar
The starter's Bendix mechanism sticking and leaving the motor engage on the flywheel a little too long. They generally only do it when the engine is cold. The Fit's starter isn't easily rebuilt to replace or grease the Bendix so I imagine most owners replace the starter.
Old Mar 8, 2022 | 04:23 PM
woof's Avatar
Sounds like the VTC Actuator problem. The only thing is that the VTC Actuator problem is usually described as a loud rattle (which gets louder over time) however it typically does show up early in the morning when you first start that car, only lasts briefly for a few seconds and then usually won't happen again in the day when the car is warmer. People getting it diagnosed by the dealer had to leave their cars overnight so that the engine could be cold started in the morning.
Honda service bulletin 16-088
Numerous threads on it here and I believe some YouTube videos on it. This bulletin is for 2015+ models and I see you have a 2008. The VTC problem however did go back to 2008 on various Honda models.
Old Nov 6, 2022 | 06:18 PM
doctor J's Avatar
Yaris MT and Acura RSX make this noise too.
All starters that are using lubricated thin wall brass sliding bushing around the solenoid plunger and black bell shape rubber boot around the plunger end
Old solenoid (center) with bell shaped black rubber boot
Aftermarket
The edges of the sleeve are worn and serrated
The reman. starters from the stores are using solenoids with nylon sleeve and very thin red rubber boot . Some cheap rebuilds show heavy lube on the brass bushing and remover rubber boot
flyingby
Mar 5, 2025 10:45 PM
sunnyday
Aug 5, 2017 01:51 AM
danielmorrison
Sep 26, 2016 09:13 PM
sdn09fit
Aug 28, 2011 12:39 AM
tanker
Jan 5, 2006 02:28 AM
