Idle Learn Procedure
Old Aug 20, 2006 | 02:37 PM
Natloz's Avatar
Originally Posted by VelociRacer
Before you get jerked around further by the Honda clowns, do yourself a favour and try the Idle Learn Procedure. To shorten the length of this process, do this:
1- Making sure you have your radio code, remove the Backup/Radio fuse in your engine compartment fuse box. Re-install after 2 minutes. Close the hood.
2- Making sure no electrical items are on, even the dome light, start the car and rev between 2k-3k rpm until the fan comes on once. Let it idle until the fan comes one the second time.
3- Let the car idle for another 10 minutes after the second fan cycle and you're done!
This is not going to hurt your car, it can only help it find the right computer settings if you're not happy about mileage, etc.
Is the "Backup/Radio" fuse the same as the #8 fuse (Keyless receiver unit, Gauge control module, Security control unit,Immobilizer control unit receiver, Audio unit)?
Old Aug 21, 2006 | 09:29 AM
bobthenuke's Avatar
Originally Posted by claymore
People if you are expecting any mileage change from the Idle rest procedure don't hold your breath. All that does is to allow the ECU to reset itself after you disconnect the battery. Then it allows for your driving style and chooses what map to use and then later it refines the process so resetting it just makes it start over and gets you right back to where it was set before you disconnected it. It also just resets the idle to the cars specs. no better no worse. No magic in this procedure.
I'm with you on this one. I performed this only as a last resort, basically grasping at straws to help things. I know that on my Toyotas this is the same thing and will affect emmisions more than anything.
All things equal, I've got to suspect ECU problems, but if it was burning so rich I'd expect to see artifacts of this in the tail pipe.
bob
Old Aug 21, 2006 | 08:57 PM
petro's Avatar
claymore...
In regards to the "idle learn procedure", if the vehicles computer was going to learn how you drive and the conditions where it is driven by itself so it can maximize whatever honda has programed into it, why have a Idle learn procedure at all?
Old Aug 26, 2006 | 10:32 PM
trowpa's Avatar
OK - anyone do the Idle Learn Procedure and have a report? I believe it would do nothing (as I think Claymore suggested) as the computer is constantly adjusting its settings, but I'd like to hear a report.... Particularly from someone that was getting in the 20's prior to trying the ILP
Old Aug 27, 2006 | 02:05 AM
crimsona's Avatar
https://www.fitfreak.net/forums/show...0&postcount=75
http://townhall-talk.edmunds.com/WebX?14@@.f0c139c/496
Old Aug 29, 2006 | 12:37 PM
hqly's Avatar
I did the idle learn procedure and it appears that i'm getting worst milage then before. I hope that is not the case.. but i'm at about half and it's at about 121.. before i would be at about 150 at half tank... maybe i should;ve left things alone and not do the idle learn.. darn it! i was getting about 29-30 all highway... was hoping for better not worst
Old Aug 29, 2006 | 01:06 PM
trowpa's Avatar
HQLY - see my reply to you in the LOW MPG thread. I would expect this myself.
Old Aug 29, 2006 | 07:43 PM
jrlnc's Avatar
hqly:
No, I never did the Idle Learn procedure because I didn't feel I needed to.
I increased my tire pressures to 38 psi all around this month when I started using the Scangauge. I check tire pressure every week to make sure it stays there because there always is some leakage.
On highway driving, I'm staying at 65 MPH (which is our speed limit) on routes that have lots of speedtraps. Elsewhere I set the cruise control to ~70 MPH and it keep the RPM's below that magic number of 3400 to keep V-TEC from sucking more gas.
Also, where possible I'm coasting in neutral and anticipating stops so that I don't waste gas that will be eaten up by last minute braking.
Old Aug 29, 2006 | 07:51 PM
trowpa's Avatar
JRLNC - that's pretty much my method as well - 38psi and very very easy on the throttle. I haven't started coasting in neutral yet, but I might on long downhill runs.
Its pretty much comon sense isn't it? More throttle you give it, the more gas its getting - so minimize throttle as much as possible.
one thing that is misleading in the manual and in many articles about driving for mileage...it is often stated "try not to vary speed" or "use cruise control as often as possible" Well, both of these are only true on a completely flat road - which most of us don't drive on. Cruise control is designed to keep a constant speed - NOT to help mileage. To help mileage you should accelerate going down hill and allow the car to slow down going up hill..thus keeping the throttle mostly steady.
Old Aug 29, 2006 | 09:28 PM
jrlnc's Avatar
trowpa, you're absolutely right as far as those driving techniques go.
We who own manual transmission Fits have a lot more control over things than the a/t owners, but with paddle shifters they might be able to accomplish some of the same things.
In real-world highway driving I can't drive like some of the Prius and Insight owners that I see every day. In theory, not using cruise control will give you better mileage, but everyone else is speeding and will ride your @ss if you slow down while going uphill.
North Carolina is very hilly, but I still use the cruise control on the highway anyway. I figure 'I paid for it, why not use it?'. It really makes highway driving more enjoyable for me and I have less tendency to speed.
Driving while glancing at my Scangauge, I have learned that city driving and accelerating from a dead stop yield the poorest MPG readings. You can improve that by using a feather-touch on the accelerator and then going neutral downhill or before a stop. The MPG for that brief interval jumps to ~120 MPG or so and that does figure into your average MPG for a trip/tank. On suburban roads where the speed limit is 25-35 MPH, I can often get 35-40 MPG by using good techniques. Complete stops, hills, and a/c use really take their toll.
Old Aug 29, 2006 | 09:55 PM
Mr SEntra's Avatar
Lightbulb
Well, I think it's opposite in California. They will ride your @ss if you are maintaining speed going downhill. It's pretty annoying because people will drive slow up the hills and then go like 90 down them. I normally have the opportunity to go into a slower lane to stay out of the drama, unless there is really slow moving vehicles.
Old Aug 29, 2006 | 11:06 PM
  #32
hqly's Avatar
hqly:
you try to stay below 3400.. i'm always below 3k on my auto.. but it still eats up gas like crazy.. i have my tires at 36.. i lost about 3-4 psi per month... so if i check in a month i will be at 32 or 31.5.. is that normal for u guys too? i was afraid i might have a leak.. one tire.. front right loses more than anything else..
3-5 psi a month does not seem normal for me.. before i drove on tires without ever putting more air in them for the longest time.. bt at this rate.. after 9 months i would be at 0 psi lol..
Old Nov 20, 2006 | 01:42 PM
  #33
hqly's Avatar
Since moderator thinks this question should be here then i'll post it here.
For those who has tried the idle learn, pelase post results after idle learn.. mines decreased a bit.. no improvement..
Old Mar 16, 2007 | 11:46 AM
  #34
mrmarried's Avatar
For those with bad MPG
Have any of the FiT owners here with bad MPG tried the ILP technique?
This is what I've read that would help you gain MPG:
Start with a cold engine.
Turn on ignition switch and make sure that every accessory is turned OFF. AC,radio,all lights, everything.
Turn off ignition switch
Disconnect the negative battery cable for 5 minutes.
Re connect cable
DO NOT TOUCH THROTTLE. Turn ignition switch on for 2 seconds, then start car.
Let it idle with all accessories turned off.
In about 10-15 minutes,in 70-80 degree weather, the radiator cooling fans will cycle. After the second cycle let idle an additional 10 minutes.
The fans will cycle some more during this additional 10 minutes.
Switch off engine. Reset radio and driver AUTO window.
Some have claimed to gain 4-5 MPG with a Sport AT. Can anyone confirm or deny if this helps?
Thanks
Old Mar 16, 2007 | 10:48 PM
  #35
bestfit's Avatar
Re connect cable
Thanks
sounds intersting.. did you try it yourself?
Old Mar 17, 2007 | 01:58 AM
  #36
jkandell's Avatar
How do you reset the driver auto window?
Old Mar 17, 2007 | 09:00 PM
  #37
mrmarried's Avatar
Sorry jkandell I just posted what I found not sure how to actually do this. Search for ILP technique through google.
Cheers.
DTTech
Nov 14, 2019 12:11 AM
radioarno
Feb 4, 2017 06:48 PM
eddyksurfer
Apr 7, 2013 11:02 PM
hqly
Nov 18, 2006 01:00 AM
hqly
Sep 4, 2006 03:20 AM
