Towing with the FIT HELP
Old Jan 29, 2009 | 08:09 AM
  #41
mahout's Avatar
Originally Posted by DrPhyzx
I disagree. It's not a technical issue.
It is a tech issue. Overseas, Jazz gets different springs and shocks. Americans don't like hard riding cars no matter how small. We get squishy sprins and shocks. Have you carried a couple of 200 pounder passengers? Its not fun.
Thats why if you are going to tow much with a Fit you need the Monroe AirLifts.
I towed my lawn tractor on the little TS trailer with and without the rear Airlifts. Towing 900 lb ( 408 kg) with the stock Fit was uneasy. No problem with the AirLifts. we didn't measure the tongue load but guess about 150 lb.
Old Jan 29, 2009 | 01:05 PM
  #42
DrPhyzx's Avatar
It's been said before. Payload capacity according to the Honda specs is about 1000 lbs. 150 lb. tongue weight is nothing from a suspension standpoint.
Any car that is towing a significant fraction of its capacity will handle quite differently: I'm not sure why you would expect otherwise. I think people are spoiled from towing things with their giant pickups and SUVs these last 10 years or so. 20-30 years ago, a 3000 lb. car was a pretty big tow vehicle and 4000 was the weight of the biggest GM sedans. Now, 4000 lbs. is a typical mid-sized car. Suspensions are also much stiffer now: spring rates and damping, than they were 20-30 years ago.
Old Jan 30, 2009 | 02:22 PM
  #43
StillHaveaFit!'s Avatar
I left my new trailer on the fit loaded with my dirtbike. Average MPG on that tank was 32mpg.
Bike Dry weight is 262lbs
Trailer Weightis 120lbs
Estimated load 500lbs +or-
You COULD see a slight drop in the rear of the car, but nothing really note worthy.
Tongue weight I didnt measure, but it well under 100 lbs. If you are near your 150lb limit, I agree better shocks and springs would be best if you were going medium to longer distances. Short rides, I still wouldnt bother.
Old Feb 4, 2009 | 09:21 AM
  #44
Here it is FINISHED and painted to Match the Vivid Blue!
Sugarphreak
38
Nov 23, 2015 09:53 PM
Xtina
Mar 7, 2014 04:12 PM
texas
May 10, 2012 08:53 PM
jhoprodie5
Mar 12, 2008 12:20 AM
woodster
Aug 30, 2007 05:06 PM
