Problems with Reverse?
Old May 4, 2006 | 11:59 AM
buttahball's Avatar
hmm...I don't have any problems at all...try going into 5th first and pulling str8 down. (make sure you're not moving forward first lol) like F&F...lmao...that movie was so BS. *cough cough*
Old May 6, 2006 | 01:35 AM
pnx-r's Avatar
That little grind when you don't engage reverse is normal. I just do what everyone else does and shift into 4th and then pull it into reverse. I find this normal because Reverse gear is a spur gear, thus the gear isn't curved like the rest of the forward gears. Therefore you'll notice a whine when reversing fast.
Old May 6, 2006 | 01:40 AM
jtsimaras's Avatar
My 06 subaru impreza is impossible to get in reverse almost every try with out putting into 1st gear first----apparently it is normal.
Old May 6, 2006 | 01:46 AM
Bukwheat's Avatar
Originally Posted by mattd00b
Anyone have trouble getting the 5 speed into reverse? Mine is sticking half way into reverse and I accidentally ground the gear thinking it was all the way in (making me cringe).
Any suggestions?
What works for me is putting it back in neutral, fully depress and repress the clutch, then put get back into reverse.
Old May 6, 2006 | 04:27 AM
moeye's Avatar
There are no synchros on reverse (don't need it). It's actually a gear slipping in between the main shaft and counter shaft. Usually, it's just a little misaligned. Doing the neutral, clutch out and clutch in will work. Another method... try shifting it into some of the other gears just to budge it just a little for that little cog to fall into place (while still have the clutch in).
Eric Satoshi Harima
Apr 13, 2019 03:28 PM
hoopmatch
Mar 26, 2017 12:54 PM
chubbs899
Oct 22, 2014 04:37 PM
Mercfh
Sep 10, 2014 08:44 PM
Shark
Jun 8, 2005 09:16 AM
