Group 26R battery works
Old Jun 8, 2012 | 11:30 PM
El-Kat's Avatar
Hi folks,
I'm new to this forum and new to forums in general. I have an '07 5-speed Fit and the battery died almost exactly 5 years to the day I bought the car. I found some info on this forum about using a 51R battery but after making some measurements decided against it. Instead I found the dimensions of the 26R to be a better fit for the fit as though it was meant to fit (sorry, got carried away). This battery is apparently used with larger engines in Neons and PT Cruisers. It's been in for a week now and all is working well. Not sure if I'm able to post a link but in case anyone wants to see it, here is a photo of the install.
web.295.ca/stepanic/Img_4492a.jpg
Ed
Old Jun 16, 2012 | 11:11 AM
jed1's Avatar
Did you have trouble with the hold down straps?
Old Jun 19, 2012 | 07:43 PM
El-Kat's Avatar
Yes, I had to lengthen the top strap (you can see it in the photo) and the one on the front hooks well enough under the battery tray. Battery is holding up very well. I have also added a small 1 Watt solar panel on my dash wired in through the fuse panel. The idea is to constantly top up the battery from the normal current draw without overcharging. I hope to have this battery last the remaining life of the car.
Ed
Old Jun 19, 2012 | 08:10 PM
Spacecoast's Avatar
the picture link does not work for me...what brand of battery did you purchase and what install issues did you run into? I think the 1st gen have more battery room. thanks
Old Jun 19, 2012 | 11:40 PM
DB4LYFE's Avatar
ive always wondered if a group 26 would work... nice to know
Old Jun 20, 2012 | 11:22 AM
FitStir's Avatar
Question
Originally Posted by El-Kat
.....I have also added a small 1 Watt solar panel on my dash wired in through the fuse panel. The idea is to constantly top up the battery from the normal current draw without overcharging. I hope to have this battery last the remaining life of the car.
Ed
What type/brand solar panel? Where (location) did you wire it to the fuse panel? Please post pics.
Been thinking of adding a solar trickle charger as well, would definitely appreciate your advice.
Old Jun 23, 2012 | 03:42 PM
El-Kat's Avatar
I bought a cheap-o panel for $10 at my local Canadian Tire store. It's housed in plastic so it's very light. I believe it's called Blue Planet battery maintainer. I wired it directly into the fuse panel since the accessory outlet is disconnected when the ignition key is out. I modified a spade connector to fit in an empty fuse socket and I used matal foil tape to connect the ground wire to an exposed piece of metal. The solar panel current is so low the resistance of the ground connection is meaningless. Here are all the photos:
http://web.295.ca/stepanic/Img_4492a.jpg
http://web.295.ca/stepanic/Img_4493a.jpg
http://web.295.ca/stepanic/Img_4494a.jpg
Ed
Old Jun 25, 2012 | 09:45 AM
FitStir's Avatar
Thank you so much Ed. Been thinking about getting one of those... now it's on my list. Can't wait to do it.
Just gotta figure out the wiring.
Old Dec 21, 2016 | 11:40 PM
radioarno's Avatar
hi your photos aren't visible to me. Can you repost the pic of the battery, and the solar panel pics. Also, what did you lengthen the battery tie down with? thanks, from Toronto
Old Dec 22, 2016 | 03:09 AM
n9cv's Avatar
I hope that you realize that you are responding to a 4.5 year old thread.
Old Aug 7, 2024 | 02:32 PM
GE.RED's Avatar
The pictures didn’t come up for me either but if anyone has any insight on this matter I would appreciate it.
erichyung
Mar 16, 2026 04:11 PM
Jensen Healy
Dec 6, 2019 02:54 PM
phenoyz
Sep 9, 2015 03:49 AM
pzriddle
Jan 23, 2015 06:31 PM
chowder
Feb 21, 2011 03:17 PM
