Front wheel lug replacement?
Old Sep 17, 2012 | 10:16 AM
mnapuran's Avatar
Just went to pull off front wheel and one of the lugs was bound up. Ended up having to break the stud (sheared off in the lug). Doesn't look like a simple replacement. Any instructions on doing it online anywhere?
Old Sep 17, 2012 | 10:49 AM
NIGHTHAWKSI's Avatar
its not that simple. i had to completely remove the hub and press (i acutally used a large socket and a hammer to knock out the bearing and reinstall it) the bearing out and disassemble the entire thing in order to get enough clearance to remove the old stud.
Old Sep 17, 2012 | 10:55 AM
mnapuran's Avatar
Okay, that would just suck! Anyone else (hoping!)?
Old Sep 17, 2012 | 11:04 AM
mnapuran's Avatar
Crap... I can't even get the factory rotors off yet! Got the impact tool, but it's not budging the lock screws. Drill em out?
Old Sep 17, 2012 | 11:58 AM
mnapuran's Avatar
Got the rotors off... but now how do you get the hub off to replace the studs?
Old Sep 17, 2012 | 12:39 PM
disconnect everything.
remove the center hub nut
then i used a pulley puller on the center of the axle to slowly pull it off the axle.
Old Sep 17, 2012 | 12:41 PM
this might helo you out
Knuckle/Hub/Wheel Bearing Replacement
Old Sep 17, 2012 | 01:57 PM
mnapuran's Avatar
Eh... I cheated and got it done
Wheel Stud / Lug Replacement
Old Sep 17, 2012 | 03:05 PM
hahahaha, clever. i wonder if that has any safety concerns.
Old Sep 21, 2012 | 02:18 PM
BallerStatus's Avatar
You can also grind off just a **tad*** of the side of the spindle and get the new studs in/out on the back side of the hub. I would shave off barely any, try to get the stud out, then shave a little more til the bad stud would just barely slip out the backside. I put my ARP studs in this way, have been driving on them hard for over 25k miles and no issues whatsoever. Just make sure and paint the area that you shaved off. Hope this helps someone else w/ this problem.
Old Jul 13, 2024 | 10:46 AM
SuperMacGuy's Avatar
FYI you can NOT replace a stud on 2009 or later without removing the hub. Appears to work on 07-08, hub design might be different.
wh22366
14
Jul 13, 2024 10:45 AM
Steven Hung
Oct 6, 2016 09:21 PM
yeahburgs
Jun 4, 2013 01:08 PM
fitster
Feb 9, 2012 11:47 AM
YJS
Nov 11, 2010 07:33 AM
