How to see the last MM code that's been reset?
Hi I haven't had my '12 Fit very long, and when the oil life reminder came on, I changed the oil and then reset the maintenance minder.
But now I realize that there could have been other maintenance codes displayed too! Is there any way to see what the previous code was, after it's been reset?
Thanks for your help!
I'm not aware of any way to check it once it's cleared.
However, with a 2012, unless you have lots and lots of miles, I would be surprised if it's anything other than an A or B/1 or 2. The differences between them are fairly minor, ranging from "change the oil" to "change the oil and filter" to "change the oil, filter, and air filters" (besides checking things like brake pad wear, CV joint boots, etc. and rotating tires and basically just making sure the vehicle is still in good shape.)
So, to summarize, just take a gander at the engine and cabin air filters and replace if they need it, do a general inspection of the usual wear items, and sleep well through the night.
Thanks for the reply, I have inspected everything and replaced the air filter and interior filter. I guess the main thing I'm wondering is if it wants me to change the manual transmission oil. I don't think I could judge based on the color. Don't really want to go twice as long as I should have.
Do you happen to know the average mileage/age the MT fluid gets changed (I have searched on Fitfreak with conflicting results). Mine is low mileage for its age: 34,000. Never has had it changed.
jlbryan027
14
Jun 30, 2015 12:16 PM
