90 Accord blower motor question
Old May 4, 2005 | 11:16 AM
Pete from Boston
Guest
Posts: n/a
The blower motor on my 90 Accord just went at the perfect time --
snowstorm, not predicted to get above freezing until at least mid-month.
I got in yesterday and noticed that 'whiff of ozone' smell
characteristic of a failing motor, and sure enough, the air stopped
coming shortly thereafter. At least when the car is moving fast enough
the flow-through gets some warm air out the vents.
I've just started looking at replacement parts, and it seems like I can
get either just the motor or a whole new blower assembly. Which makes
more sense? What are the issues involved?
halo2 guy
Guest
Posts: n/a
Re: 90 Accord blower motor question
the motor probably will not come with the fan attached. If you are
confident you can remove the blower fan without damage then just get the
motor. These things usually come off easily with a little wd-40 and
patience.
For the quickest replacment get the entire assembly and swap.
"Pete from Boston" <masspete@my-deja.com> wrote in message
news:4225f0e3$0$559$b45e6eb0@senator-bedfellow.mit.edu...
> snowstorm, not predicted to get above freezing until at least mid-month. I
> got in yesterday and noticed that 'whiff of ozone' smell characteristic of
> a failing motor, and sure enough, the air stopped coming shortly
> thereafter. At least when the car is moving fast enough the flow-through
> get either just the motor or a whole new blower assembly. Which makes more
John Ings
Guest
Posts: n/a
On Wed, 02 Mar 2005 12:01:20 -0500, Pete from Boston
Are you quite sure it's the motor and not the motor speed reducing
resistor? That's in the air plenum behind the glove compartment. Might
be wise to check that before ripping the world apart.
Pete from Boston
Guest
Posts: n/a
Nope, not at all. I got a lot of opinions/stories that indicated my
symptoms were consistent with the motor going. I'll look into this resistor.
John Ings
Guest
Posts: n/a
On Wed, 02 Mar 2005 14:05:16 -0500, Pete from Boston
Might be wise. If it is the motor, it may have overloaded and burnt
out the resistor, which is just a few coils of resistance wire mounted
on a plastic block that sticks into the airstream in the plenum.
SoCalMike
Guest
Posts: n/a
which would likely have the same smell.
Tim Zimmerman
Guest
Posts: n/a
> > Might be wise to check that before ripping the world apart.
> resistor.
If I remember correctly, you will find two pin connector right at the
bottom of the motor to supply power to.
If I remember correctly, the motor has brushes you could snap on
snap off. If not then you could always try to clean the
communtator. They can gum up in the winter climates.
tomb
Guest
Posts: n/a
||| mid-month. I got in yesterday and noticed that 'whiff of ozone'
||| smell characteristic of a failing motor, and sure enough, the air
||| stopped coming shortly thereafter.
|| Might
| resistor.
The highest level of airflow goes from 12V through the motor directly to
ground, no resistors involved. Even if all of them in the pack are blown,
the max level will still work.
Pete from Boston
Guest
Posts: n/a
> || Might
> | resistor.
On the contrary, I do get some airflow at a very low rate. If there's
any difference between the high and low settings it isn't readily
apparent. Both produce about what would usually come from the lowest
setting.
There's a new sound, now, too, coming from someplace hard to peg in the
right half of the dash, a sort of whirring when the blower is on.
Something not spinning right.
I'll have to pull out the Haynes and the tools this weekend and have a
look in there.
John Ings
Guest
Posts: n/a
On Thu, 03 Mar 2005 11:35:13 -0500, Pete from Boston
>setting.
You might accomplish a cheap fix by disassembling the motor and
lubing its bearings.
Sean
Guest
Posts: n/a
Can you get the motor out without removing the evaporator?
"John Ings" <nodamned@spam.org> wrote in message
news:tehe21dslqse3jvr8195nl4p09quav1i3q@4ax.com...
>>setting.
Woody
Guest
Posts: n/a
All this time speculating on here and you could have it apart by now and
determine what is bad. Everything here is pure speculation and won't fix a
thing.......
news:42273c42$0$566$b45e6eb0@senator-bedfellow.mit.edu...
>> || Might
>> | resistor.
> On the contrary, I do get some airflow at a very low rate. If there's any
> difference between the high and low settings it isn't readily apparent.
> Both produce about what would usually come from the lowest setting.
> look in there.
Guest
Posts: n/a
This raises my next question. I have the blower retaining nuts all off,
but there doesn't appears to be room to pull the flanges off all the
bolts to unseat the blower and get it down. Is it possible to do this
without removing more than the two far right dash screws? I can't
really see what's holding it back. I could remove the evaporator
(really don't want to), but that's not in the direction of movement I'm
having a problem with.
I've also removed the bottom cover, though that's mostly just given me
a better handhold.
Lots of people have said "just play with it a while." I've played with
it a while. Maybe there's something specific someone has learned from
getting it out?
Billburg
Jan 22, 2025 10:03 AM
valk97
164
Jan 9, 2025 05:06 PM
hoopmatch
May 4, 2019 08:19 PM
Seanhan
Dec 6, 2016 06:10 AM
Spacecoast
Jun 4, 2013 12:59 AM
