Water/Meth(anol) Injection!
Old Feb 12, 2010 | 04:48 AM
Konservative's Avatar
Does anyone use water/methanol injection for a NA vehicle? It seems to make sense on paper...Higher octanes, cooler intake temperatures... but would it be worthwhile in a vehicle that will not be built substantially?
Also is the injection before the IAT sensor? It has to be otherwise Fuel/Air would be off correct?
It looks like it could be fun, but what gains could I expect?
I am tossing around the idea (not very seriously) for a CB7 with a F22a1 engine.
Old Feb 12, 2010 | 12:06 PM
Schadenfreude's Avatar
I don't see the benefit in a NA engine unless you have a high compression ratio.
Old Feb 12, 2010 | 02:31 PM
azkikersfit's Avatar
but im sure it will benefit a turbo fit
Old Feb 12, 2010 | 05:15 PM
i think you'll easily gain engine knock. :D
Old Feb 12, 2010 | 06:55 PM
Snow performance seems to think their product will not cause knock, and even in NA applications, provide on the order of 10-15 HP.
Can someone explain Why exactly it would, or could, cause knock?
I am checking for the f22a1 compression ratio now....
Turns out compression ratio is 8.8:1 (From KBB.com). What do you guys and gals think?
camerakid22
Nov 22, 2016 07:24 PM
Soon2015FitWillBeMine
Jun 17, 2015 09:52 AM
loudbang
14
Dec 30, 2013 12:07 AM
WhEreZmYFiT
20
Mar 10, 2010 01:01 PM
pcs0snq
Apr 15, 2008 12:51 AM
