Racing A place to discuss upcoming and past Fit racing events.
JCrim's Road Racing Thread - Stay Tuned!
Old Sep 13, 2011 | 08:40 AM
  #501
dled1286's Avatar
Originally Posted by JCrimson
i used the OBDII diagnostic port. easy mode.
heres the video that i used too incase you need it super easy mode. (i wanted it too haha)
NTD Throttle Contoller Setup - YouTube
yeah i planned on using obdII just cuz i really dont wanna spend time cutting, splicing, heat shrinking and all that jazz...(<--nice pun>.<). Last thing, did your fit stall any or get sluggish while it was "relearning" the electronics?
Old Sep 13, 2011 | 09:50 AM
  #502
JCrimson's Avatar
Originally Posted by Java^FiT
Hey man just wanted to say you're fit has convinced me to want the 949 6ul's for my ge...just deciding on widths at the moment...
easy decision! 9s and 8s! lol i dont know how they will fit on the ge, but regardless of what people say and do, if i had a ge, you can bet your ass i'd have those hoes on there. with or without fenders. lol
yeah!
nope. its was 100% fine
Old Sep 13, 2011 | 09:55 AM
  #503
Java^FiT's Avatar
Well I totally would go with 9's and 8's but its a bit agressive for me since its just a dd, and on top of that i dont have the camber you do. I was looking more towards the 7.5's all around...i want to be able to rotate them without worrying about tire direction and staggered widths...
If i get the 7.5's or even 7's im just trying to decide on tire sizes and whether or not i want a little stretch...
i was thinking for either of the 7 sizes i could do a 205/55/15 and have some nice beef to my tire finally
Old Sep 13, 2011 | 10:20 AM
  #504
JCrimson's Avatar
if you are going to get 7.5, go ahead and get the 8s, you will not regret and tires are cheap. for an 8 get 205/50/15. its the fastest tire combo for that wheel size per spec miata real racers. also, if you want even cheaper, get the 7" and use a 195/50/15. same rule applies to them.
If you want to rotate and not worry, Id just get the 8s. looks great and plenty of meat and not too over board. lots of tire choices!
if you plan on staying with the L15 with no FI, the 7s will work perfect too.
all in all, i would just get the 8s.
Old Sep 13, 2011 | 10:45 AM
  #505
Java^FiT's Avatar
is there a reason why i shouldnt go with a 205/55/15? that is the closest to the stock 185/55/16 diameter and circumference...
Old Sep 13, 2011 | 10:48 AM
  #506
JCrimson's Avatar
the 55 is a bit tall and will increase the rub chance for sure. also, its probly a little bit softer and more sloppy feeling. what kind of tires you want? i forgot to ask that, i naturally assume extreme summer tires. .
Old Sep 13, 2011 | 10:51 AM
  #507
Java^FiT's Avatar
some high perf all seasons...something like a kuhmo ecsta asx for instance.
i think im going to run into clearance issues with an 8" +36 up front...its 7mm less inner clearance and 19 more outer than what i have now...
And if not a 55 on a 205 how about a 215/50?
Old Sep 13, 2011 | 10:55 AM
  #508
Java^FiT's Avatar
and i wouldnt mind a slighter taller tire anyway, im always worried about scraping crap as it is. lol
Old Sep 13, 2011 | 11:08 AM
  #509
JCrimson's Avatar
Like i said I dont really know about the GE8, but in my case, its almost like no matter what the specs said, the crap just worked for me. of course ive always had mass camber. not to fit the wheel but because i wanted it for track.
here is what the indifference in oem wheel vs my front wheels now. I dont rub at all and i track this thing where the suspension compresses the most.
only mods that could account for this is 1. the fender liner pop up trick, 2. my 12k front springs, 3. -3.0° camber in the front.
here is the comparison pic
Take in mind this program would NOT let me choose 9" wide wheels with a 225 tire. my current setup is 15X9 et 36 with 225/45/15s
so the results would be even more extreme than this. this is kind of like a slightly sugar coated version due to the programs limitations..
Old Sep 13, 2011 | 11:15 AM
  #510
Java^FiT's Avatar
What program is that and where can i get it?? haha thats awesome
If its not possible for me to get that program would you mind plugging in the following data for me
185/55/16 Stock Tire
16x6 +55 Stock Rim
205/55/15 Choice #1
15x7.5 +42 6ul
205/50/15 Choice #2
15x7.5 +42 6ul
Old Sep 13, 2011 | 11:27 AM
  #511
JCrimson's Avatar
Old Sep 13, 2011 | 12:15 PM
  #512
Java^FiT's Avatar
Sweet! that's an awesome utility this is what I'm looking at now using a 15x8 +36 compared to my current 17x7 +42
Old Sep 13, 2011 | 02:10 PM
  #513
Java^FiT's Avatar
i keep looking at this going...i want more beefy i think i might end up just buying the 205/55's and if i absolutely hate them ill just buy the 50's
I just cant make up my mind between 7's and 7.5's...the 7s are cheaper tho...thats probably whats going to sway me.
Old Sep 13, 2011 | 02:16 PM
  #514
JCrimson's Avatar
if you dont mind me asking, why are you so stuck on the 55s? try the 50s and you will feel very compelled to write me a huge thank you love note and rep me . haha
Old Sep 13, 2011 | 02:18 PM
  #515
JCrimson's Avatar
here is the basic chart we go buy
15X7 = 195/50/15
15X8 = 205/50/15
15X9 = 225/45/15
15X10 = 275/35/15
these are the fastest tire to wheel combo.
Old Sep 13, 2011 | 02:43 PM
  #516
Java^FiT's Avatar
well right now i have a 205/40/17 which sucks because its very low pro and im sick of dodging pot holes. that is foremost #1!
secondly, that is already a smaller diameter than the stock 185/55/16 and the 205/50 is even smaller still. so instead of getting my car lower to the ground and adding beef id rather add beef and get it back to stock height clearance.
i believe its as such - bold is stock and closest match, blue is current, red is your suggestion
185/55/16
Stock Diameter: 610 mm
Stock Circumf: 1915 mm
205/40/17
Current Diameter: 596 mm
Current Circumf: 1871 mm
205/55/15 - Closest
Future Diameter: 607 mm
Future Circumf: 1906 mm
205/50/15 - Your suggestion
Future Diameter: 587 mm
Future Circumf: 1843 mm
Old Sep 13, 2011 | 02:52 PM
  #517
JCrimson's Avatar
haha okay i see your goals now. i understand. Sorry for over looking your needs I get excited when it comes to the twisties lol
Old Sep 13, 2011 | 03:17 PM
  #518
Java^FiT's Avatar
Hey no worries at all, if anything im glad you questioned me because it forced me to actually think about it more...Im sure after my warranty expires I will buy a nice CO system(which i had but had to sell ughhh) and lower the car, add camber and make it much more track friendly and when i do, different tires will be necessary anyway. but i think I will be very happy with some of these 6ul's in a 15x7, unless of course you convince me to get the wider ones lol.
Old Sep 13, 2011 | 03:26 PM
  #519
JCrimson's Avatar
here's a pretty pic of the 8s vs 9s
fish eye for added effect lol (only lens i have haah)
http://www.flickr.com/photos/jcrimson/5941084555/http://www.flickr.com/photos/jcrimson/5941084555/ by http://www.flickr.com/people/jcrimson/, on Flickr
Old Sep 13, 2011 | 03:36 PM
  #520
Java^FiT's Avatar
GOPR0074 by JCrimson, on Flickr
damn those 8's look sexyyyy...i might have to take some measurements tonight to see if itll work ahhhh
