Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
FIT IPOD questions
Old Mar 28, 2007 | 08:32 AM
  #81
WhatFreshHell's Avatar
Seems to me that if it is in your glove box, it will be out of site.
Does it really need to be actually mounted in there?
Old Apr 6, 2007 | 06:16 PM
  #82
rebecca's Avatar
If you get the Monster cable you also need the the stereo mini plug cable too? Monster cable goes from the bottom of i pod to the accessory plug or the "cigarette lighter"? Then where do you plug the mini plug cable?
Old Apr 6, 2007 | 07:17 PM
  #83
aznguyen316's Avatar
Originally Posted by thr3
If you are willing to spend a few more dollars, Monster cable makes a harness that plugs into the bottom port of the Ipod and allows "smart" charging from the 12v accessory outlet. More importantly, it has an 1/8" audio out jack with line level output from the Ipod. This will give you better sound than plugging in to the top earphone jack and you won't have to crank the volume of the Ipod real high to hear it through the Fit stereo. You'll still need the $5 cable with a 1/8" stereo mini plug at each end.
I got mine at CompUSA, but they are now closed in the Houston area.
This is what I just purchased. It was from the Sik store though as I couldn't find the monster cable one, but it charges and uses uncompressed line out audio =) yipee
Old Apr 6, 2007 | 09:06 PM
  #84
thr3's Avatar
Ipod Monster cable
For whatever reason, the Monster cable has a jack at the bottom of the docking port plug for the line out audio along with a 12v accesory power cable that is terminated with a plug. They should have terminated the adapter with a separate audio lcable and plug, but chose to put a jack on the adapter instead. So to get the line out audio to the Fit, you still still need an audio cable with 1/8" stereo plugs on each end. One goes to the Monster docking port adapter line out jack and the other end goes to the aux input jack on the Fit.
Old Apr 7, 2007 | 02:34 PM
  #85
dcmoore's Avatar
This is exactly what I've been looking for. Do you have a link to the monster cable that you used?
Old Apr 7, 2007 | 04:59 PM
  #86
thr3's Avatar
Monster Cable
Here's Crutchfield's catalog listing for it:
Monster iCharger For charging and powering the iPod in a car at Crutchfield.com
Old Apr 9, 2007 | 02:38 PM
  #87
dcmoore's Avatar
Thanks.
I found it on Amazon and it is a bit cheaper. If you are prepared to try some of their third party vendors it can be bought for as little as $1.87 plus shipping. Here is the link:
Amazon.com: Monster Cable Ultra-Low Profile iPod iCharger (AICHG2 IP): Electronics
Old Apr 16, 2007 | 03:58 PM
  #88
Yusio's Avatar
iPod/MP3 on Jazz/Fit
Hi everyone,
Having just opted for a Honda Jazz (UK), there's just a couple of things I need cleared up. The thing is pre-2006 Jazz/Fit's don't have the aux/mp3 connector in the UK (I'm presuming it's not the same everywhere) and I've got a 2005 model.
I asked the dealer about it, he said they can't install the connection, but I would be able to find after-market solutions. So I've been fishing around for such solutions and I've looked at the DIY sticky here, which I think is what I need but I'm not confident about DIY myself unfortunately.
I've also found the Dension ICE systems appealing, but they are very expensive here, and I'm not sure if needs fitting too.
I was wondering if there are any better solutions than those two mentioned.
Thanks for any help.
Old Apr 16, 2007 | 05:16 PM
  #89
SpoonSportFit's Avatar
https://www.fitfreak.net/forums/fit-...ighlight=input
here is a link to one that is for the usdm fit, for auxiliary input it is diy i don't know if you want this but, i know that here sony makes an inexpensive headunit that has the aux input in the front,
hope this helps a little
Old Apr 29, 2007 | 06:01 PM
  #90
Fit of RAGE's Avatar
it just looks better that way. more professional
Old Apr 30, 2007 | 03:47 AM
  #91
CuTeBoi's Avatar
I have this one... i think, but it does the job....
http://www.discountcarstereo.com/ima...s/pxp01v_l.jpg
Don't forget to set the TV out settings on the ipod if you hook it up to your LCD screens in your car =P
Old May 7, 2007 | 01:27 PM
  #92
thank you, I've been looking for a car mount, I could do with a universal one but I'll check this out.
Old May 7, 2007 | 02:38 PM
  #93
smatts's Avatar
Honda Fit Forums Moderator
Have you considered Window Vent Visors? This might prevent the splash when you open your windows. But we warned they do impeded your vision slightly once installed.
Old May 19, 2007 | 04:23 PM
  #94
coldstorage5's Avatar
How can u hook up an IPOD Cheap???
Hey,
How can you hook an Ipod with out the $160 honda wire/set up????
Is there a cheaper way to do it??
Thanx,
CS
Old May 19, 2007 | 05:05 PM
  #95
explosivpotato's Avatar
If you have the sport model, go buy a stereo mini extension cable. plug one end into the ipod, the other into the AUX jack near your 12v power outlet. 6 bucks.
if you dont have the sport model, i think there is a way to wire an AUX jack in. Do a search.
Both of these options are waaay cheaper and easier to use (from what I hear) than honda's ipod link thingie.
Old May 19, 2007 | 05:41 PM
  #96
What is this???
is it this???
eBay: 3.5 3.5mm AUX AUXILIARY CABLE CORD FOR iPOD CAR STEREO (item 220111889671 end time May-19-07 23:47:31 PDT)
Thanx for the input.
I have some long trips coming up, and money is really short. 2 kids, wife at home, etc....
Old May 19, 2007 | 05:47 PM
  #97
arsonall's Avatar
you know the plug that you insert into the headphone jack on your ipod? look at radioshack or something for a cord that has two of these on it, one on each end. plug one end into the ipod headphone jack, the other into the AUX jack by your cigarette lighter. remember to turn the stereo to AUX so you can hear it. you still control the tracks through the ipod.
edit: just saw your link. yes, that is exactly it.
Old May 19, 2007 | 05:51 PM
  #98
Thanx man, That a lot cheaper!!
our the best
Old May 20, 2007 | 10:54 AM
  #99
thr3's Avatar
Ipod Cable
For a few dollars more, you can get this one which allows charging and also connects the audio via the Ipod dock, so it's line out and not from the headphone jack. This gives better sound in my opinion and the Ipod volume doesn't have to be cranked way up.
http://www.monstercable.com/computer...ple%20Products
Old May 29, 2007 | 10:25 PM
  #100
charliehart1's Avatar
ipod connection?
i tried to get the ipod connect thing for the glove box but apparently honda discontinued this
do you know any place i can get it done on my stock audio system?
