Steering wheel removal???
Old Oct 12, 2007 | 11:33 AM
bangdango's Avatar
Can someone write up or have the correct safe way to remove the steering wheel from the sport fit??
Need to take off the silver plastics. left side broke and im stuck.
PM me, make a new post, or reply here with it.
PLease I need help quick!
~abris
Old Oct 12, 2007 | 12:46 PM
George02's Avatar
~abris
Im not sure wat youre talking about. post pictures of wat youre talking about... Im probably the only one thats done it by myself
Old Oct 14, 2007 | 02:19 AM
Illusive's Avatar
FITFREAK.NET AND MYSELF WILL NOT BE HELD RESPONSIBLE IF YOU GET HURT OR IF SOMETHING BREAKS FOLLOWING THESE INSTRUCTIONS! I FOUND THESE INSTRUCTIONS FROM AN ONLINE EDM MANUAL FOR AN 05 FIT!
Now that I got that out of the way, disconnect the battery and wait at least 3 mins. The ESM says that you have to remove the access panel below the steering wheel. That gives you access to two Torx bolts on either side of the steering wheel as well as the harness for the SRS airbag. Disconnect the airbag connector and remove the Torx screws on either side of the airbag to remove the airbag. This will give you access to the two screws that hold those plastic pieces in place.
zeniitti
Aug 31, 2017 03:34 AM
fidget247
May 30, 2011 03:33 PM
Red Diablo
Jan 10, 2010 11:31 AM
Lek
Dec 12, 2008 11:04 AM
GROC80
Oct 9, 2007 02:31 PM
