Quote:
Originally Posted by zfr846
I've got a lot of questions to ask about the Honda Jazz/Fit L13A engines... I am a fit owner myself. I got a 1.3 M/T and i wanted to know about some stuff. First of all, what do you think about having a turbo kit installed?
Can the stock pistons, intake manifold handle the pressure of F.I.? or will this go up in flames? (kaboom?!!! perhaps?) Do you need an emanage to control fueling and air?
Hi. I have a turbo 1.3 M/T Jazz for 2 years now.
Yes you can use the stock pistons and intake manifold. I know somebody that runs 12psi of boost with this set-up. I run about 7 psi myself.
Yes, I believe you can use emanage to control fueling. I have a piggyback that controls a 5th injector.
Thanks.
