Is Wheel Alignment covered under the New Car Warranty?
I went in to get an alignment check after hitting a giant pothole in Lawrence, KS. My Left Rear is a bit over with a 0.33 degree toe. Does anyone know whether wheel alignment is covered under the Honda warranty?
Note: the pothole was hit with the front right, not the left rear.
Thanks in advance!
Also, watch out if you're ever in Lawrence, KS, the city does not take care of their roads!
Thanks in advance!
Rear wheel alignment of a USDM GE appears to require either a new rear axle or bending of said axle. If anyone can be more authoritative on this please confirm. My parts catalog shows just the axle, spindle to spindle one part. My left rear tow is minimally out, your .33 is going to chew up tires.
An alignment due to physical damage is not covered by warranty.
Sorry for not clarifying, the flat I had from hitting the pothole was on the front right, which was within normals for the alignment. The Left Rear didn't actually get close to the pothole at all. That's why I was wondering if it's more of a factory defect vs. accidental damage.
I do plan on fixing mine but likely will do so with brute force. Mine is enough that if you leave a tire on that corner more than a few thousand miles it starts a diagonal wear bar in the tire. Of course, I have these shite Bridgestone EL470s.
This will NOT be covered under warranty since it is damage from road hazard and not a defect, sorry! BTW I have about 5 curb/pothole damaged accord rims in my garage that I have collected over the past year, they should make great planters once spring comes!
You would have to spin it carefully, make it sound like you got it messed up not you damaged it and you may have a shot. That is just how you need to deal with dealers....I don't like it either...
Yeah and the toe is only off on one side right? That is gonna be bad for sure. Although it would be an excuse for new tires soon if you wanna just rotate em until they all die.
Hmmm... i guess i have a different take. Don't try to scam the dealer off something shoddy like this. No it's not covered and if you are upset about the cost, send the bill to the City of Lawrence and demand the pothole be fixed.
I'd try to avoid letting them know you're a Mizzu fan though
Odie
11-25-2015 07:16 PM
Jim Grames
12-20-2014 11:03 AM
