Hot to install a Cusco Front tower bar in a GE8
Old Oct 24, 2008 | 04:52 PM
AshPanda's Avatar
How* not Hot
Ok I have another thread for the rear strut bar but in wanted a fresh one for the front so here it goes
I started off removeing the cowl panal plastic
Then i set the bar up in there and found which bolts to remove to install it.
and then tighten then up and barly cleared the brake resivor i had about 1mm of space cleared
but then i popped the cowl back on and it was done
here are some bonus pics
Old Oct 24, 2008 | 05:07 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
looks good
nice right up also.
hows it drive now with both
front and back done?
man that is close on the brake res
thats going to suck when you have to add
fluid or change it. but then again how often
does that happen
Old Oct 24, 2008 | 05:24 PM
mole177's Avatar
whats that blue bar in the middle of the engine bay? does it make the bar a 3 point?
Old Oct 24, 2008 | 06:17 PM
AshPanda's Avatar
Originally Posted by niko3257
looks good
nice right up also.
does that happen
well there is a offset bracket that i am still waiting on to fix the brake res problem. the front bar wasn't saposed to fit but it did. and it made a world of a difference, more responsive steering. i love it
I'm not sure why it is there but it had hardware and was in the instuctions
Old Oct 24, 2008 | 06:27 PM
BlackUp's Avatar
how long did it take to remove the cowl? is it a pain?
+1 rep
Old Oct 24, 2008 | 07:01 PM
TWGE08's Avatar
Another good job +rep. Can you give us more info on how to remove the cowl?
Old Oct 24, 2008 | 08:09 PM
AshPanda's Avatar
It just pops off with a little presure. but take off the ends first
Old Oct 24, 2008 | 08:11 PM
JDM_DOHC_SiR's Avatar
Thumbs up
WOW !!! it FIT`s..... Another great DIY
Old Oct 24, 2008 | 08:49 PM
More pic`s of around this area Eric!!! when you can
Old Oct 24, 2008 | 09:04 PM
AshPanda's Avatar
i'LL GET THOSE AS SOON AS I CAN!
Old Oct 24, 2008 | 09:16 PM
Thanks.....
Old Oct 25, 2008 | 01:14 AM
Yes... 3 point ( kind of )
Old Mar 11, 2009 | 02:06 AM
EK3 Ferio's Avatar
Awww looks great! I think I'll get one this weekend and post it here to.
Thanks AshPanda. Too bad no pics of where all the clips to be removed are located but I remember passing by a PDF somewhere on the net showing how to remove it.
Old Mar 11, 2009 | 02:27 AM
EK3 Ferio's Avatar
There we go its in the sticky "DIY lower your GE" how to remove the wiper cowl cover its applicable here.
Old Mar 11, 2009 | 02:48 AM
EUROz*JDMz's Avatar
Looks great, but how are you supposed to refill the brake fluid?
Old Mar 11, 2009 | 06:26 AM
EK3 Ferio's Avatar
Same question as the above?
Also, if I have no plans of installing that middle piece thing I have no need to remove my wiper cowl cover?
Old Mar 11, 2009 | 06:38 AM
EK3 Ferio's Avatar
One last follow up question: Its just one bolt on each side holding it down for the strut bar itself?
Thanks!
Old Mar 11, 2009 | 08:57 AM
one bolt per side and one in the center... and as for accessing the brake res on a USDM car they make a bracket that lowers the res down about 10mm for the USDM version other than that the bars are the same
Old Mar 11, 2009 | 11:33 AM
AshPanda's Avatar
As often as i change the brake fluid on my 2009 fit, i'll just pop off the bar when i finally do.
Old Mar 11, 2009 | 11:48 AM
redrumm's Avatar
i can get rear strut bars and a sway bar
for the GE for those of you that are interested
