slightly hot air in vent
Old Aug 11, 2009 | 09:01 PM
lostpacket's Avatar
This weekend I noticed the AC wasn't quite as cool as I expected. Since I have only owned the car for a week, I thought it was normal, especially when the ambient temps were pretty hot in my area.
I also noticed that the incoming air with no AC and the recycle lever set to allow outside air is always a little warm. As a former mechanic it either seemed like it is poor design or a heater core flap not shut all the way.
I found this thread from another guy with the same problem.
link to thread
My question is, do any of you know the best way to access the flap on page #2? I don't want to spend a ton of time searching if someone has already ran into this and fixed it.
thanks
Old Aug 11, 2009 | 09:15 PM
Committobefit08's Avatar
Originally Posted by lostpacket
Mine does the same but all I do is turn the AC on for a minute. Flush all the hot air out then turn off the AC and the air is cool. Problem solved.
Old Aug 11, 2009 | 09:27 PM
lostpacket's Avatar
I can flush out the hot air and it still goes back to being warm. Even when the ambient temps are cool, it is warmer than it should be. This coincides with AC temps that are a little off too.
Old Aug 12, 2009 | 04:02 PM
handymus's Avatar
We just bought 2 fits. 1 just a month ago, and the other one, last Friday. The first one has this problem, and I was driving around thinking, "gee, this car is hot". Changing to recirc helps, and you can feel a temp. difference of air coming out of the vent. The 2nd fit is not bad at all...maybe slightly warm air.
Hopefully someone found a solution, but it sure sounds like the temp. vent is not closed all the way, since it obviously is not a thermostat control.
handymus
Old Aug 13, 2009 | 12:11 PM
12vltfrk's Avatar
there is a long post on this the ac cycles on and off, when its on its cold, when its off, its warm. ck out the link https://www.fitfreak.net/forums/2nd-...peratures.html
Old Aug 13, 2009 | 09:37 PM
handymus's Avatar
Not with A/C on
Just using the fan to push air. It appears that the vent is not closing all the way to block the warm air.
Old Aug 13, 2009 | 09:54 PM
Tyrsis's Avatar
TBQH, the Fit just doesn't have very good AC. I drive my girlfriends TSX from time to time, and it will spit out ICE COLD air on a 100 degree day like nothing.
Mshellt
Jul 12, 2016 04:23 PM
myc0p
Aug 25, 2011 12:04 PM
Granit
Aug 31, 2006 01:26 AM
JKR
Aug 28, 2006 09:20 PM
Jisch
Aug 26, 2006 03:13 PM
