power wire for amp
Old Aug 17, 2009 | 09:53 AM
12vltfrk's Avatar
power wire for amp
any owners of a 09 fit run a power wire for an amp yet, if so please let me know of all the diffrent ways you have done so. i have just put in the vm9022 head unit last night and ran all the wires. the stock radio was a pain to get out!but its done!
Old Aug 18, 2009 | 04:50 AM
supafly50's Avatar
i haven't got a 2009 fit, i have a 2007 jazz, but i pulled the power wire from inside the cabin through to the engine bay by cutting a metal clothes hanger, bending it straight, hooking it around the wire, sticking it into an existing hole in the firewall, then pulling through from the engine bay. it was pretty tough but well worth it!
Old Aug 18, 2009 | 12:53 PM
12vltfrk's Avatar
well im running 0awg wire, its a little to big for that, if i dont get any help im just going to get a firewall bushing kit
Old Aug 18, 2009 | 03:47 PM
Yes, I Vtec's Avatar
just cut a hole... that's what ive always done
Old Aug 18, 2009 | 05:23 PM
Kouki's Avatar
Look at the IASCA install thread a few threads down.
Old Sep 30, 2009 | 03:20 AM
Lyon[Nightroad]'s Avatar
why 0 awg? 8, hell, 12 awg will handle anything the stock alternator can put out.
Old Sep 30, 2009 | 01:27 PM
MetalFit630's Avatar
Yikes! 12g would be scary. The only thing I'd be willing to run off a 12q wire would be a 200 watt inverter. Anything else would draw a lot of heat. 8g is fine if you're just doing a small 4 channel amp. I used a 4g for my two amps, and it runs great. In my opinion, 1/0g is freakin huge, and not really necessary for the majority of applications. But if you're pushing a 2000 watt RMS system, then 1/0g you need. But you'll also need to upgrade a number of electrical components under the hood. I'm not an electrical engineer, but 1/0g is just plain huge.
Old Sep 30, 2009 | 04:26 PM
Yea, I was exagerating a bit there. only my speaker wires are 12ga.
Old Sep 30, 2009 | 08:10 PM
bikethis's Avatar
+1
Fairly easy to get to, once the air cleaner is removed. It enters the cabin right where the clutchpedal arm will push on it, it needs to be secured in-board before routing it behind the trunk-release cover.
ck42
May 12, 2017 08:22 PM
CBX
Nov 26, 2015 02:24 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
iFit08
15
Mar 12, 2011 12:41 PM
1RMDave
Sep 12, 2007 10:55 PM
