Mileage reports: Manual transmission (5MT)
Old Jul 2, 2008 | 10:46 PM
  #701
RichXKU's Avatar
Wow... where can I buy gas at $3.80??
Old Jul 3, 2008 | 10:02 AM
  #702
pb and h's Avatar
where I live it goes for $3.75 a gallon
Old Jul 4, 2008 | 03:10 AM
  #703
bdrake's Avatar
I clicked over 6400 miles recently (and finally changed the oil from factory break-in to Mobil 1), and I calculated my lifetime mileage with the Fit:
6416 miles / 153.1 gallons = 41.9 mpg
Wheee!
--Barry
Old Jul 4, 2008 | 11:41 AM
  #704
pb and h's Avatar
Alright, I have pumped the tires up 55psig, I will need to get a new tire pressure gauge because I just realized mine only goes to 50psig. So, I had to use the gauge on the air pump at the gas station.
Peep this article: Before you over inflate watch this. - Page 3 - CleanMPG Forums
I think I will try 60 psi on the next tank. The mpg gurus seem to get the best mpg and longer life at 60 psi without compromising safety.
Old Jul 6, 2008 | 01:36 PM
  #705
pcs0snq's Avatar
Just got back from a trip to the Smokey Mountains. I think I may of been in Shane's neck of the woods. I-95 to I-26 West to I-40 into Bryson City. No phone no WWW just me and the fam chillin'
Took the wife's 1999 V6 AT Accord. 2000 miles RT. Set the cruse for 72 and recorded 33.5mpg reg gas. No hyper-milling tech at all. Car has 140k miles. WOW the hills. I also got some of that $3.78/ gas. Was great to wake up in 51F weather I'll mis that as I'm home and it's back to swamp conditions.
I'll be starting the week with my Fit tank avg at 53 and just past 1/2 tank. I'd like to see if I get 60mpg for the tank and a 600 mile tank this fill. Last to runs using P&C was 60 and 65mpg
Rich nice job on the new record.
Old Jul 6, 2008 | 03:51 PM
  #706
pb and h's Avatar
Just an update - I drove 210 miles at 55psig and noticed a bit stiffer ride(which is expected) than at 50psig. I was driving the speed limit(60-70mph) using cruise control encountering very little traffic on the interstate and noticed no handling differences than at 50psig.
NOTE: I forget how the FIT handles in the 30psig range.-seriously.
I used A/C (the wife is demanding) so I will be lucky to get 45mpg this tank.
I purchased an air pressure gauge that goes up to 60psig and had my tires rotated and balanced - I think they decreased my psig because the ride feels softer.
Old Jul 6, 2008 | 06:23 PM
  #707
RichXKU's Avatar
I can remember... it's crap! lol
66.4 MPG for me over 15.8 mi back from Lowe's & Haircut.
Tank is at exactly half with 324mi. (within 3 mi of half tank on my 55 MPG tank). If conditions stay good I'm hoping to be close to 550mi again before fillup.
Old Jul 6, 2008 | 10:04 PM
  #708
pb and h's Avatar
Well, I just filled up with 8.6 gallons and went 415.6 miles = 48.3mpg at $3.81 per gallon. I used a Wal-Mart gas station so the gallons are suspect but I guess it will average out.
This tank had 210miles of highway driving going the speed limit from 60-70mph using cruise control and A/C I would think it would of been around 45mpg.
I just pumped the tires to 60psig and it is raining here, the true test of traction, and I have not noticed any down side to the higher pressure even taking corners fast like I usually do to conserve that fuel. The tires don't look bad. I will have to take a picture to show you people.
Old Jul 6, 2008 | 10:38 PM
  #709
pb and h's Avatar
Here are some pictures of the tries at 60psi and 32k on them:
I do not notice any bulging of the middle of the tire which was my major concern. The drive to work tomorrow will be the true test.
Old Jul 7, 2008 | 08:34 PM
  #710
pcs0snq's Avatar
Got 62mpg to work and 60 coming home today. 24 miles
My 600 mile tank may be next tank.
Old Jul 8, 2008 | 04:18 AM
  #711
SukebePAUr's Avatar
60psi?
i sit safe to be driving at 60psi? it seem a bit high to me.
Old Jul 8, 2008 | 12:18 PM
  #712
pb and h's Avatar
That is what I am trying to find out. You will have to draw your own conclusions as I am trying to do that now.
So, I have put ~200miles on the tires at 60psig and have notice what SEEMS to be better handling around corners and a few more seconds longer at coasting. I haven't notice any decrease in braking(I don't remember what normal braking is like). The bumps and uneven ground are very noticeable but tolerable.
The Cornering is subjective - what seems to be handling better may be do to the car skidding and me not noticing since I don't hear the wheels chirp.
Old Jul 9, 2008 | 07:49 AM
  #713
SukebePAUr's Avatar
i thought tires increase in pressure as they are warmed up from driving, i just don't want to blow a tire while i'm on the freeway. that won't be fun at all
Old Jul 9, 2008 | 07:20 PM
  #714
JBElliott's Avatar
New update for the latest fill-ups:
Gallons Miles Tank's MPG (#)
10.102 424.90 42.06098 (1)
9.134 379.50 41.54806 (2)
9.284 409.80 44.14045 (3)
That's 11 straight 40+ mpg tanks in a row now.
In general, I filled up one click past the shut off, I did quite a bit of drafting, kept my speed under 65 mpg, but over 55 mpg, a lot of downhill in neutral gliding on the highway, some pulse and gliding and shut off the engine and costed up and waited at long traffic lights.
(1) and (3) were my usual commute driving with some A/C during the 95+ days. (2) was more city driving with passengers and A/C. (3) I worked in more FAS with some gliding to red stop lights and FAS gliding down a big hill off the highway.
Just adding up the total gallons and miles gives: 245.11 gallons over 9450.0 equals 38.55412 miles per gallon.
Finding the mean mpg of the fillups listed above gives 38.51939 mpg with an error on the mean of 0.6140019.
Either way it looks like the lifetime average for my Fit is 38.5+-0.6 mpg.
My CleanMPG chart keeps looking nicer all the time:
I made a fit to this plot with mpg=a*(1.0-b*exp(c*x)) where x is number of days since my first fill-up, that is x=1 is the "day number" of my first fillup. This is my simple attempt to estimate the "limiting mpg" of my Fit. That is what is the mpg as x tends towards infinity. Based on the mpg data I've recorded the fit gives a limiting mpg of 52.6+-0.4 with a chisquare of 1.1, not too shabby. The fit is good (I'll show it when I get a chance) and the value of the limiting mpg agrees well with some of the better mpg reports posted on this forum.
Old Jul 9, 2008 | 07:28 PM
  #715
solbrothers's Avatar
got 50.9mpg going to in n out burger. and 51.3mpg coming home
Old Jul 9, 2008 | 07:55 PM
  #716
pcs0snq's Avatar
how many miles each way and what speed
Old Jul 9, 2008 | 07:58 PM
  #717
pcs0snq's Avatar
You are right at the point I was 2 weeks ago and doing the same stuff that works for me. If you want to make a +10mpg leap, start pulse a gliding. Ask and I tell you how I do it.
BTW That white dotted line in the Cleanmpg trend, is the mean line for your data set
Old Jul 9, 2008 | 08:02 PM
  #718
10 miles each way. driving ~50-60mph. depending if i could catch a draft from a truck :P. hit some nasty traffic for a few miles too. i was surprised on my fuel economy. it is so freakin hot lately in the SF bayarea. that helps the mpg's
Old Jul 9, 2008 | 08:16 PM
  #719
pcs0snq's Avatar
Originally Posted by RichXKU
Paul: a few people, and myself seem to get higher than usual readings during engine-off glides. I drive so infrequently that I haven't been able to draw my own conclusions yet, as I had moved the scanguage to my STi for one tank.
I still don't know, but my LAG indicator is starting to make me wonder. I do not glide with eng off when I'm doing my P&G thing.
I still have a way to go before I get the results.
Just now I have 1/4 tank left and miles on the fill
SG has the same miles as above and says I have 3.0 gals left (to 10.0 only) and calc's 163 till empty at my current tank rate of 54.6mpg So if that works out it will be 549 till E. 600 seems out of reach based on the cars indicators.
I started the P&G after I ran some on this fill so even though I get a SG reading of 60 at the end of my day (49miles) the average is still off from that.
It's a great deal of work to P&G in traffic and try and draft the best I can.
BTW It has not been said, but between you and Shawn, I think we are all trying to hit the bell and as a result we keep getting better. I'm going to put my 1 gal fuel jug in the car and lean on it this time lol
Old Jul 9, 2008 | 08:18 PM
  #720
pcs0snq's Avatar
Yea that pretty funny
It was 81 at the crack of dawn here with about 90% humidity Go calc the heat index. lol
