DIY on Installing Xenith Xenons HID Kits
Old Jul 18, 2008 | 01:16 PM
  #121
azncarbos's Avatar
interesting...I need to hear this myself.....cool I still need to set a date for the meet
Old Jul 30, 2008 | 05:47 PM
  #122
B1str0's Avatar
RubberBabyBuggyBumpers
Followed your DIY up to the mounting of the brackets because the HID's i got had different brackets for the ballasts so i had to drill new holes above the second one u specified for mounting, but nonetheless great writeup and i cant complain for getting 8k bi's for 70 bucks from my neighbor lol
Old Aug 16, 2008 | 03:17 AM
  #123
YA2_user_GD3's Avatar
Just got my kit installed today. My lights worked fine, until the left went out. Is this normal? It flickered just only once and that was the last of it. It won't turn on AT ALL and I've rechecked my wires all over again. It worked fine for a good 15 minutes. The peculiar thing is that I have the H4-2 so my halogen hi-beam actually works perfectly with only the HID left side not functioning.
I've heard of the break in period but it won't turn on completely and I've checked wiring and tried to restart my car etc. to reset anything. Is this a normal thing for the XX bulbs/kits to do this? Please help thanks.
Old Aug 16, 2008 | 10:36 AM
  #124
azncarbos's Avatar
No that is not normal to XX kit and the break in period all the light will just flicker once and go back to normal......what you can do is switch the bulb around and see if the left will go out again.....then if so switch around the wiring....trying to remember that wiring order.....
Old Aug 16, 2008 | 03:39 PM
  #125
What's even more odd is that I worked on the left side first(non-functioning side) until i perfected it then I mapped the right side EXACTLY like it. Now only the right works. I'm beginning to think it's the bulb but I'm going to check once more.. it's such a bitch to do for the Fit.
Old Aug 23, 2008 | 04:29 AM
  #126
Super Mario's Avatar
I had somewhat a similar problem. I have bi-xenon XX kit. My left side high-beam worked, the right side did not. Both low beams worked fine. I switched the bulbs from one side to the other and now both work fine. So if you have time, try switching the left and right side bulbs to see if that helps. Good luck.
Old Aug 23, 2008 | 06:21 AM
  #127
cKranez's Avatar
hey is it normal for a buzzing sound coming from the boxes from the hids? its like a little buzzing or humming sound
Old Aug 23, 2008 | 06:35 AM
  #128
Yeah, I think that's normal for the ballasts to be buzzing. Mine do it, and at least I think it's normal.
Why am I still up so late...
Old Oct 6, 2008 | 05:32 PM
  #129
OneStopCustoms's Avatar
would it be the same thing for the hid fogs?
Old Oct 6, 2008 | 05:40 PM
  #130
XenithXenons's Avatar
It'd be different for the fogs since the wiring is in a different location, but the general way of connecting the kit to the car is still the same.
Old Oct 7, 2008 | 03:39 PM
  #131
azncarbos's Avatar
thank you George, the location for the ballast is place below and closer to the fog light. I will doing a DIY soon for the HID Fog...
Old Dec 11, 2008 | 02:16 AM
  #132
azncarbos's Avatar
Bump I need a GE8 around SoCal who want to install HID!!!
Thanks,
Peter
Old Dec 13, 2008 | 10:25 AM
  #133
WOOHOO I found the topic again lol
Old Dec 20, 2008 | 03:11 AM
  #134
Bump to the top
Old Jan 30, 2009 | 02:21 PM
  #135
trancedsailor's Avatar
all the pics from the first page don't work
Old Feb 20, 2009 | 08:26 AM
  #136
zeemon's Avatar
ok this may be a dumb qestion, but in the DIY i dont think there is any mention as to where the 3 prong plug is to be plugged into? then in this image:
on the right side of the image there it is..its plugged into something, but what?
Im having problems finding where to plug this in..any help would be great! i need to get this done before the afternoon hits.
Thanks in advance
Old Feb 20, 2009 | 10:48 AM
  #137
pwnstar's Avatar
Thanks in advance
the plug, plugs into the passanger side wireing harness for the headlights (is that what you ment?)
Old Feb 20, 2009 | 11:40 AM
  #138
azncarbos's Avatar
if you are installing bi-xenon the 3 prong plug into the OEM 3 prong on the driver side only....
Old Feb 20, 2009 | 11:48 AM
  #139
zeemon's Avatar
right, thanks guys!
just finished the install - turns out my question really was dumb :s hehe.
I love my new lights !
thanks for the diy azncarbos!
Old Feb 20, 2009 | 11:52 AM
  #140
azncarbos's Avatar
No worry man!!! there never a dump question!
Good to hear you already enjoy your HID!!
