Just got my new 2015 FIT
Old 07-19-2015, 12:19 AM
Paz_Honda's Avatar
Hello
I want to put 17" Motegi Racing FF7 GunMetal clear coat with polished lip rims. 4 lug with +42mm offset(I don't even know what +42mm offset means)
Tires I want are Nexen N7000
Should I put a spacer on or are the rims gonna be flush with the car????
I am really new to this car & putting rims on something.
Any help would be appreciated.
Old 05-15-2016, 08:51 PM
Alfie's Avatar
NO, you do NOT want to use spacers!
Old 05-16-2016, 06:43 PM
dwtaylorpdx's Avatar
If you use spacers, Use H&R spacers. If you can get them specific to your car, H&R's match the hub and hub center so there is NO slop or wobble. You will need to install longer ARP lugs to do it right, H&R sells them as a kit for some cars.
Cheap spacers will severely screw up eventually..
Make sure you have a selection of tires you like in 17" ,, I have found in the past some sizes are un-obtanium in 17"
Old 05-16-2016, 08:29 PM
xxryu139xx's Avatar
OP was from 2015... why res this thread?
Old 05-17-2016, 11:12 AM
Alfie's Avatar
For anyone who comes across this thread in the future who wants to see an answer to the OPs' question!
A 17x7" +42 wheel is the max spec for the average person who wants a healthier looking wheel and to lower the car a bit.
If the OPP does a 5, 10, 15 or 20mm spacer with this spec wheel it is gonna make it look like a mudder truck!
RolandoB16
07-23-2015 08:10 AM
lister
11-02-2012 12:27 AM
liverpoolfcfan
04-19-2012 06:34 AM
jnesselroad
14
03-05-2012 05:24 PM
Java^FiT
02-10-2011 03:46 PM
Quick Reply: Just got my new 2015 FIT
