TIRE questions,sizes, mounting,pressures ANY tire questions
Old May 27, 2006 | 09:27 AM
  #161
jim@tirerack's Avatar
Former Vendor
I do not have the stock wheel weight. I do have most of the weights of the wheels we carry. If I can help let me know.
Old May 27, 2006 | 01:24 PM
  #162
smeister's Avatar
Hey Jim,
Will the 16x7 Kosei K1 TS including the right tires fit on the Honda Fit? Thanks
Old May 28, 2006 | 08:11 PM
  #163
bigtime13's Avatar
kumho 7-12's i have used em on 2 different cars and im goin 2 put em on my fit when i get my rims.... they are super dope in the rain and when its warm out they sick 2 the road like glue... and u DONT need 2 replace em every 3 months like other hi performance rubber plus they are cheapper than other name brands!!!!
Old May 28, 2006 | 08:41 PM
  #164
jeebus's Avatar
Kumho MX. Don't mess with the 712's, they are crap. MX = cheap, relatively long lasting, MAX perf tire. They sell a 205/50/15 but I don't know if they sell anything correct for 16".
I have run many tires on my BMW M3 and the MX is my favorite. Bests many tires twice the price.
Old May 28, 2006 | 08:54 PM
  #165
dougiepants's Avatar
Avid FitFreak Poster
Goodyear GS D3's are rockin on my GD3 and I'm lovin them...
Old May 28, 2006 | 09:09 PM
  #166
fad3r's Avatar
I liked my Falken ze512s and my new Fuzion ZRi's on my Fit.
Old May 28, 2006 | 10:23 PM
  #167
rsmigel's Avatar
My fit set at 50psi at the dealer
I picked up my new M/T Sport Fit Friday and checked the tire pressure cold today. Every tire was @ 50psi!
I guess I'll back off to 40 psi.
Old May 31, 2006 | 08:53 AM
  #168
Former Vendor
Choosing a tire is all about what you want from the tire. If it is just looks you don't have to buy the best tire on the market. If you are plus sizing almost all of the available tires are going to handle better than the OE tires.
If I can help just give me a call or email.
Old May 31, 2006 | 08:56 AM
  #169
Former Vendor
I don't have the 16" K1-TS for the car.
Old Jun 1, 2006 | 01:55 PM
  #170
annie's Avatar
This thread is super interesting. I went out and bought a tire gauge yesterday. All my tires were around 34-35 psi.
Old Jun 1, 2006 | 06:41 PM
  #171
xorbe's Avatar
@rsmigel: I would go back and complain (or at least edumacate them..)
34-35 is fine. As the recommendation is 32 psi, I wouldn't go 10% out of spec myself (+/- 3 psi). However, 40 psi is a whopping 25% more pressure, and 50 psi is 56% over!
Old Jun 1, 2006 | 07:30 PM
  #172
eyedryve's Avatar
The tire just says it can tolerate 51#'s. If you put that tire on a 1500lb car, like a first gen Mini, then it will only deform so far. Deformation is important to increase tire contact patch. Same tire, on a car which weighs 4000lbs, will be squashes flat at the same cold PSI. So, the tire manufacturer knows what the tire can tolerate, but the car that it's riding on DOES matter, a lot. Choosing a specific tire isn't rocket science though- same size, likely uses about the same pressure for a given car, if tire design is fairly consistent. If you Autocross your fit, and buy stiff sidewalled, sticky race-compound tires, the tire's likely gonna deform less than would a "standard" mileage tire. So the tire matters too.
Bottom line- Honda knows how heavy the car is, and how it was designed. They sought a tire to work well with it, and recommended a tire pressure. It's a starting point only. I'd recommend not going too far away from it- like the post above, +/- 10%- sensible. (Why less? Maybe snow/ice... Heck, I don't know...) OK how about +10%....
And you don't have to buy the same exact tire next time. If you buy a similar tire, do similar things with pressure. If you buy something different, the pressure probably should be different too.
I like to look at the sidewall under the rim- if it's squashed too much at recommended pressure, add air
Old Jun 5, 2006 | 10:30 AM
  #173
Former Vendor
The Fit and the Fit Sport do come in different original height tires. So the larger tires will work on the car and speedometer will be changed slightly but no damage done.
Old Jun 8, 2006 | 04:13 PM
  #174
bjc's Avatar
bjc
Fit Sport Wheels and Tires available
Looking to sell my stock Sport Wheels & Tires for $500 obo:
http://sandiego.craigslist.org/pts/174861479.html
Preferably in or near San Diego county, to avoid shipping hassles (and extra cost).
---Thanks
Old Jun 11, 2006 | 02:43 AM
  #175
mightyjazz's Avatar
Rim/tire Comparison Guide
If we plan to install wheels/tires with different sizes/offset from OEM sizes, we should be aware of the result = possible differences between speedometer reading and actual speed, clearance with fender or brake system. BTW we can do simulation prior to actual installation with the rim - tire comparer : http://www.rims-n-tires.com/rt_specs.jsp
Old Jun 13, 2006 | 02:17 PM
  #176
Former Vendor
Wow, good luck with that. Everything we show on our web site does fit the car and we have tested them. We also can tell you what size tires are needed to keep the same diameter as stock.
Old Jun 14, 2006 | 10:37 PM
  #177
Need new tires :(!!!!!
Well that is right. Running maxed out camber at this ride hieght in the picture below killed the tires completely in right about 4 weeks. The camber is around -3 to -3.5 and the toe is nothing close to stock... poor tires... But great handling LOL...
Old Jun 14, 2006 | 10:39 PM
  #178
LiL Wee FIT's Avatar
Gotta give some to get some! LOL
Old Jun 14, 2006 | 11:03 PM
  #179
aziatiklover's Avatar
Master FitFreaker
sucks man oh well look> buying tires every month lmao
Old Jun 15, 2006 | 12:08 AM
  #180
sillypuddy's Avatar
Someone that Posts too much
so does anybody have the alignment data yet? my mechanic say without the specs, i can't get the alignment done
-joe
