BI-XENON HID help
Old Jan 17, 2009 | 07:54 PM
kodo's Avatar
BI-XENON HID help
so i just finish installing the kit that i got from XenonVisions
my driver side hi beam is not working. i swap the blaster from passenger side to the driver side to see if that was the problem but it wasn't the case. can it be the bulb ?
Old Jan 17, 2009 | 09:43 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
I'm sure it's the harness the ballast has nothing to do with your high beam not working, check your wire connections.
Old Jan 17, 2009 | 10:26 PM
kodo's Avatar
i unplug everything and reconnected everything still the same.
Old Jan 17, 2009 | 10:35 PM
Formerly "bitoy"
what kit do you have? bixenon or HI/low? try switching the prongs around that connects to the stock headlight harness.
Old Jan 17, 2009 | 10:37 PM
kodo's Avatar
its bixenon kit
Old Jan 17, 2009 | 11:27 PM
Fit of RAGE's Avatar
Have you checked the fuses? Some HID ballasts have connectors that can fit backwards. (positive and negative can be switched) Check to see that the plugs are the correct way. Take a VERY close look! I've made that mistake before.
Old Jan 18, 2009 | 12:03 AM
kodo's Avatar
i'll recheck everything out on friday + swtiching the bulbs around.
Old Jan 18, 2009 | 08:02 AM
M@lew's Avatar
So it's only the hi beams? Low works fine?
Old Jan 18, 2009 | 01:23 PM
kodo's Avatar
yup driver side low beam work but hi don't come on.
Old Jan 18, 2009 | 05:39 PM
Kuturagi's Avatar
Hey u should just take some pics of the install and post them to let us help you out. I just installed the Xenith Xenon kit and my hi/low work just fine! Bi-xenons can be tricky sometimes but if you have it wired wrong then things tend to happen. What kit do you have?
Old Jan 18, 2009 | 09:18 PM
koolkevin1107's Avatar
yeah xenith xenon's kits are excellent but he has xenith vision's kit, one i haven't had any experience with.
To the OP, i would just switch bulbs to see if the ballasts and the relays are working fine. If u switch the bulbs and it doesnt work, its the relay. If it does work, it's the bulb's actuator.
Old Jan 18, 2009 | 09:35 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
BI-xenon, as in 2 xenon bulbs per socket, the only real REAL bi-xenon, has EVERYTHING to do with the BALLASTs.
1 low beam xenon with 1 halogen high is NOT bixenon, bi means 2
1 xenon bulb moving to change the focal point in the reflector housing is NOT
bi-xenon, bi means 2
a REAL BI-XENON system has 4 ballasts, 2 for the highs and 2 for the lows, therefore.......u have been duped into buying a fake "bi-xenon" set-up
if the passenger side high beam does not work but it does work when u swap the bulbs from left to right and then the drivers side high beam stops working then u know for sure that the high beam bulb (or the wire/connector leading from the bulb) is defective.
u know that the ballast is ok because it now lights the newly swapped bulb
u know that the wiring harness is ok because it lights the swapped bulb
u know that the fuses r ok because there is only 1 fuse per hi/low circuit, (both highs would not light up if fuse was blown)
my guess is that there is a bad connection where the wire actually meets the bulb (inside the bulb's base).....u need a new bulb assembly (that is the whole hi/lo bi-xenon, socket, wires and the connectors) NOT the wiring harness or the ballast or the other bulb assembly
Old Jan 18, 2009 | 09:40 PM
SFactor2's Avatar
if he has an "actuator" he does NOT have bi-xenons
the thread is clearly labeled "BI-XENON HID help",
NOT "low beam only"
or "single xenon hi/low moving"
or "low beam xenon, high beam halogen"
"BI-XENON" means 2 that is TWO XENON bulbs per socket (for a total of 4 xenon bulbs for the hi/lo system"
Old Jan 18, 2009 | 09:42 PM
SFactor2's Avatar
if u have it wired wrong, then MORE THAN 1 bulb will not work
Old Jan 19, 2009 | 03:44 AM
kodo's Avatar
here you go
Old Jan 20, 2009 | 04:17 PM
kodo's Avatar
update so yesterday i got home at night i notice my low beam was out too on driver side. so today i switch the bulbs today low beam works and high beam works only if i have the car running or else only one bulb will work. and it makes a noise like bzz when i turn on the lights i don't know if i don't have enough power to run the lights because i have an ampflifer connected to the battery too. i swap out all the speakers and the head unit is not OEM.
Old Jan 22, 2009 | 04:35 PM
kodo's Avatar
replace the blub today everything is working now woot
Old Jan 22, 2009 | 04:40 PM
SFactor2's Avatar
told ya it was the bulb
Old Jan 24, 2009 | 10:46 AM
TWGE08's Avatar
Any pics of the install and the lights? I'm debating whether I should install mine or not.
Old Jan 24, 2009 | 12:49 PM
TunaDaMan's Avatar
i just wanted to point out the Illustrationtion 2, great spelling on their part, sorry it was annoying me
corps
Feb 21, 2011 06:37 PM
n4t3s6
36
Aug 11, 2010 06:40 PM
phuccer
17
Jul 16, 2010 04:36 PM
stnl619
Dec 24, 2009 12:40 PM
FITtin'
Dec 9, 2008 04:29 PM
