TIRE questions,sizes, mounting,pressures ANY tire questions
Old Jun 28, 2006 | 01:18 PM
  #201
dougiepants's Avatar
Avid FitFreak Poster
Well the GD3 is raised 1/2" and I am waiting to get to get the new tires mounted and the car aligned...
bad news...
Pass. tires has cord showing on inner and outer sides. Some steel belting is starting to poke out on the outer side aswell.
Drivers. has just dead tire tread and looks like racing slick...
This is all in 5 1/2 week mark... I'm glad I have the 10th AE RX-7 to drive lol
Old Jun 28, 2006 | 01:43 PM
  #202
jim@tirerack's Avatar
Former Vendor
I think you have set the record for quickest wear on a Fit. Are you sure you were not drifting?
Old Jun 28, 2006 | 03:16 PM
  #203
siownschu's Avatar
are there any companies thats planning on releasing a camber kit for the fit?
Old Jun 28, 2006 | 03:29 PM
  #204
I have camber kit on the GD3. No I was not drifting lol. The GD3 will not drift...
Old Jun 28, 2006 | 09:25 PM
  #205
brainfood's Avatar
That sounds like a challenge. I will post pics when it happens
Old Jun 29, 2006 | 03:00 AM
  #206
We have tried a few simulations of drifting. The GD3 is not designed to drift. Once it notices the car start to drift it becomes loose then grips even more... This is at slow 15-30mph and High 90-110mph
Old Jun 29, 2006 | 09:45 AM
  #207
siownschu's Avatar
i dont get it if you have a camber kit why dont you adjust your camber so you wont wear out the tires as much?
same thing with the toe too?
Old Jun 29, 2006 | 11:02 AM
  #208
brainfood's Avatar
Im sure with a little adjustment on the coilovers you could get it to drift. I used to drift my 4 dr honda civic sedan with just an abrupt lift throttle on a long sweeper. A good idea of wieght transfer is key, though I am not sure how that solid beam rear reacts I need to look at it a little closer, probably check it out when I install the springs. If I ever find any I like
Old Jun 29, 2006 | 03:00 PM
  #209
Hey I use to drift the old EG hatch with ITR in it all day, but the GD3 rear suspension is all about the grip lol
Old Jun 29, 2006 | 10:26 PM
  #210
brainfood's Avatar
thats funny, I havnt pushed mine yet so I am not sure where the limit is. I want to get it out on the track but waiting for springs. Want to make it a track car but I already have 2 and dont need a 3rd
Old Jul 10, 2006 | 05:03 PM
  #211
bryan720's Avatar
what tires will fit.
ok now i got a 15 * 6.5 with a 38off set. just woundering if a 205/55-15r or 205/50-15r will fit without rubbing o and i have it droped on the t1r springs.
Old Jul 12, 2006 | 10:31 AM
  #212
Jimmy101's Avatar
Light weight tires ?
Can someone recommend some light weight tires?
For our stock sport 15" rims.
I checked tirerack that lists weights of the tires, but everything
is at least 18 lbs!
thanks
Old Jul 12, 2006 | 01:16 PM
  #213
Former Vendor
Both of the sizes you mention will fit fine. You can also use 195/55R15 and 215/50R15 on the car.
If I can help let me know.
Old Jul 12, 2006 | 02:19 PM
  #214
Former Vendor
I would worry about the weight of the wheels not the tires. The tires can reduce weight at the price of reducing performance. The weights we list on our web site are shipping weights and normally they will weigh a little less anyway.
Old Jul 17, 2006 | 12:22 AM
  #215
spider2k's Avatar
if you are worried about weight then u need to start with removing your entire interior. strip all the dampening material. start buying carbon parts.
if you get soooo far as to need lightweight tires...
Old Jul 17, 2006 | 02:17 AM
  #216
aziatiklover's Avatar
Master FitFreaker
wheel weight ftw tires dont count
Old Jul 17, 2006 | 12:48 PM
  #217
ccFit's Avatar
Hoosier, they are pretty light compare to RA-1 LOL
Old Jul 17, 2006 | 01:05 PM
  #218
carlosalicea's Avatar
The konig helium's at some tread in here are pretty light!!!! 10 pounds, and there are lighter ones, but very expensive
Old Jul 17, 2006 | 01:08 PM
  #219
ccFit's Avatar
he is looking for light weight tires not rims
Old Jul 17, 2006 | 01:12 PM
  #220
ok ccFit my bad........
Jimmy101,
Anyway, Light tires?????? Let that thing to car manufacturers, there are millions of things to worry and care before even think of light tires....... and instead of light tires, you should think of sticky tires which I belive is really important
