horrible gas milage
Old Jun 7, 2009 | 05:38 PM
ffaceoff's Avatar
Angry horrible gas milage
hi guys,
I bought my honda fit sport 2008 (automatic transmission) on april 08.
On the beggining I was geting arround 275 km on tank (33-35 l) wich was a horrible experience but I was told it will get better after the engine breaks in so I waited.
Now, (after the first oil change and 10 000 km) I"m avarage 11l/100km.
My best tank was 340 km for 35l.
I drive it just in Vancouver (east and downtown) so there is lots of stop and go on my way to work and home.
I never speed just normal driving but I still belive this millage is absolutly bad?
I'm complitly disapointed in the fit!
My old 92' accura integra AT (1.8 with 140 hp) was using 10l/100km!
how is this possible???
any sugestion?
thanks
ffaceoff
Old Jun 7, 2009 | 05:54 PM
Spooling's Avatar
get it diagnosed
Old Jun 7, 2009 | 06:45 PM
FELIXY69's Avatar
Originally Posted by ffaceoff
hi guys,
any sugestion?
thanks
ffaceoff
when i was NA i was about the same
Old Jun 7, 2009 | 07:01 PM
Aspires's Avatar
+1 with Felix.. im getting 340km a tank. maybe because the gas tank is smaller?
Old Jun 7, 2009 | 07:40 PM
spoonek4's Avatar
Where do u travel between again? Where in E.Van & where in DT?
Stop & go driving definitely is a BIG factor on bad gas mileage. Another thing is u may notice your brake pads may wear out faster than a lot of other ppl coz u're always doing stop & go driving.
I will suggest u to check tire pressure & perform an alignment check also. Facked up tire pressure & alignment setting never helps on getting good gas mileage.
And yeah, the gas tanks in our fit are pretty small. I usually put in around 33L everytime & I can do around 365km travelling between Metrotown to Clark & Powell area; compare with putting in around 40-45L & do the same mileage in my civic SiR before.
Change engine oil a little more often & use 89octane gas btw. Dirty engine oil & oil filter never helps. And the engine runs quite a bit smoother & responds faster with 89octane(regular plus) gasoline.
Old Jun 7, 2009 | 09:24 PM
fitster's Avatar
i got the same milage when i first got my fit after i did my 3rd oil change im now getting 400+ kms
Spooling's Avatar
wow those are some really low numbers posted above...
turbocharger here;;
i get 430-465km (full tank) depending on octane and style of driving. could be that i live in richmond so there are no hills.
i get more kms by using #94 but Washington state no have #94.
Old Jun 7, 2009 | 09:52 PM
zonianjohn's Avatar
How you drive determines alot
I notice the difference quite a bit when I drive hard.
You should try driving like an old person for at least one week and see if it makes a difference.
Soft starts, coast to lights, drive speed limit, see some of the other posts on AT mileage.
Old Jun 7, 2009 | 09:55 PM
zonianjohn's Avatar
also
My mileage went up a little when I went to a SRI and new exhaust.
Old Jun 7, 2009 | 10:08 PM
blackvitzrs's Avatar
doesn't the GD fit have a 42L gas tank? The GE only has a 40L tank.
ffaceoff
Canada Fit Forums & Clubs
54
Jul 21, 2015 05:02 PM
mimibici
Sep 14, 2011 11:26 AM
andre181
Oct 22, 2008 10:20 PM
ffaceoff
19
Jul 30, 2008 06:12 AM
tershel
48
Sep 3, 2007 12:40 PM
