Taking oil pan off
Old Jun 9, 2009 | 03:00 AM
Spooling's Avatar
Taking oil pan off
Has anyone taken the oil pan off before? What do you need to do to take it off? Is it hard?
Old Jun 9, 2009 | 03:28 AM
speedoholic's Avatar
Why do you need to take off the oil pan? I'm sure if you have a set of wrenches, sockets and a new gasket you'll be good. You might wanna specify what chassis and engine you have.
Old Jun 9, 2009 | 04:20 AM
kelsodeez's Avatar
UNBANABLE
its pretty straight forward. just follow the instructions.
to remove
Engine Oil Pan Removal
to put back on
Engine Oil Pan Installation
Old Jun 9, 2009 | 02:44 PM
Spooling's Avatar
Thx
Another Question
Where is the oil line? Where should I weld the oil return fitting? What size -AN fitting ?
Old Jun 9, 2009 | 03:55 PM
kelsodeez's Avatar
UNBANABLE
im getting under my car today. ill try to take a pic
oh and the fitting should be a -10
Old May 7, 2020 | 08:42 PM
thats_it's Avatar
Do you need to remove the driveshaft? It's in the removal instructions but not the installation instructions.
to remove
to put back on
Old Jul 11, 2020 | 11:26 AM
LGJVFX's Avatar
Did you ever receive a reply to the inquiry about removing the drive shaft? Not my car, but I'm researching for my friend. Initial impression is that driveshaft removal seems really involved and beyond our ability.
Old Jul 11, 2020 | 12:31 PM
thats_it's Avatar
I didn't get an answer from the forum but I did get an answer from taking the pan off myself. The answer is no! Which is good because the driveshaft removal would have probably been beyond my ability too.
I have the pan off now and I'm waiting for the new pan to arrive to complete the job.
Old Jul 12, 2020 | 02:11 PM
LGJVFX's Avatar
Ah-ha! Many, many thanks. I have yet to get under car fully to assess. Planning a patch as initial solution. Looks like might be just a pin hole rather than a stress crack. Any instructions you found or advisory comments are very appreciated.
TYIA!!
Old May 26, 2021 | 07:05 PM
zacinnc78's Avatar
i hit a concrete culvert and cracked my oil pan earlier so im getting ready to tear into it soon .Any advice or problems anybody ran into ,cant find any youtube vids on this job but i appreciate the links someone posted above .My questions are do i need a gasket and also liquid gasket (i dont think either one comes with the part on amazon).Also someone in another thread showed some metal tubes in the corner of his old oil pan and said he couldnt get them out but he thought they neeeded to go back in the new pan? Any help is much appreciated!
PS 2008 fit sport automatic
Old Oct 29, 2022 | 02:21 PM
Dannynines's Avatar
So I'm doing my oil pan and it's basically glued shut any advice for removing it with it being stuck?
Old Oct 30, 2022 | 03:17 PM
TunaDaMan's Avatar
I would say check double around the oil pan to see if you missed a bolt, I did when I dropped my pan years ago. The bolt was around one of the corners you wouldn't notice at first, check this link, then maybe a nice wide flat head, should be a nice corner you can get into and twist, that won't damage or is at least away from the mating surfaces.
Old Aug 12, 2024 | 01:13 AM
Willowick2506's Avatar
Oil old pan is off but….
I went through all the work to replace the oil pan on my 09 fit. As I finally broke the old one loose I realize there is a black metal bracket right in the way of the pan dropping. I’ll attach a picture this bracket is right by the rear of the17mm bolt that mounts to the torque converter. First does anyone know what this is? Secondly can I take it off without causing other issues?
Black metal bracket is right in the way
Skwigelf
Apr 27, 2016 11:47 PM
gOzP19
Oct 18, 2014 01:04 AM
richsfit
Nov 7, 2012 06:10 PM
Selden
May 10, 2010 02:08 AM
hogwylde
Mar 29, 2010 04:02 PM
