rear strut tower bar functionality (does it really make a difference?)
Old Jun 11, 2009 | 07:37 PM
  #61
fit-aficionado's Avatar
I think the best bar for this area of the car is the Cusco, but from the design it seems it'd take a lot of stress at the red arrows. If it'd be reinforced with a couple of bolts to the car where the red circles are, it'd be perfect.
Old Jun 12, 2009 | 06:08 AM
  #62
revd34's Avatar
to bad i can't show you my rear strut bar. i have sworn to not show anyone yet by the request of the company. it nice. it mounts on the rear seat brackets too
Old Jun 12, 2009 | 02:08 PM
  #63
Jazz GD3's Avatar
When I first got my strut bars, I got the Tanabe front and rear strut bars, I "think" I did feel a difference. Whether it did make a difference or not, I believe it was very minimal, and I wouldn't mind, cuz at least it looks good.
Made my car probably feel stiffer, but it understeered a bit more, prob cuz the body cannot flex. But anyways, I recently had to take off my strutbar due to it blocking my cargo space (the Tanabe one bolts on top of the rear dampers;shocks).
Anyways, Im deciding whether or not I should put it back on due to space. My question is, would a C-pillar bar do anything, like make up for not having a rear strut bar?
Ima drive my car a little more without the rear strutbar to figure if it really does make a diff or not again.
Old Jul 14, 2009 | 09:23 PM
  #64
TheImmortal's Avatar
Originally Posted by fit-aficionado
O Kkkk... back on topic. I just wanted to know if the rear upper strut bar(the one that connects to the upper rubber mounts inside the car) was worth installing or not..
what struts r on the headliner?
it is a reinforcement bar
the "strut" in strut bar actually means something
Old Jul 14, 2009 | 09:31 PM
  #65
NO such thing as a "rear strut bar" on a honda fit
strut bar is NOT a single word
it is a bar
like monkey bars not monkey strut bars
like barbells not strut barbells
a bar that reinforces 2 struts is called a strut bar, the rear of the fit HAS NO STRUTS
Old Jul 14, 2009 | 09:36 PM
  #66
too bad i can't show u my imaginary rear strut bar.....it is blocked by the bar that reinforces the SHOCKS
if u actually understood the difference between a strut and a shock u will come to the obvious conclusion that a "shock" bar is quite useless and quite possibly detrimental
Old Jul 14, 2009 | 09:46 PM
  #67
secondspassed's Avatar
Yes I am in sales, and I dont need to be a mechanic. I have been discussing this product with a few people and from our discussions, just like kenchan said, When put on a stock car you get the "Feeling" of better cornering, but when you really Setup your suspension it actually makes it worse. You no longer are able to attain a "Nuetral steer". A car that oversteers too much is like a car that understeers too much. NOT GOOD. A Nuetral steering car is where you want to be, But that is just simply unattainable with a rear swaybar. I also Emailed Progress about how their product works, and I received some mediocre response with a one sentence explanation of "It stiffens the torsion beam". Please dont discredit me simply because I sell cars, I know what I am doing. Like I said I knew I would get flamed for this, so I knew I would get negative responses. Im sure we can sit here and argue all day and argue about yes they do work or no they dont, just like the strutbar threads.
I know I'm way late on this, but aren't you arguing that the PRSB cannot work due to its design and also simultaneously arguing that it works too well? The (not overly) simple response of "it stiffens the torsion beam" is exactly what it does, it's very simple. Your argument that the Fit doesn't need one is a different matter, I'll give you that, it's debatable depending on different setups.
Old Jul 14, 2009 | 10:19 PM
  #68
redrumm's Avatar
mine works fine. :P:P:P:P:P:P:P:P:P:P:P:P:P
Old Jul 15, 2009 | 09:29 AM
  #69
eldaino's Avatar
Originally Posted by TheImmortal
I think most people r confused.
the fit DOES NOT HAVE REAR STRUTS therefore it is NOT a rear strut brace
the fit ONLY HAS STRUTS ON THE FRONT
struts r structural AND they dampen the springs
if u remove the front struts the wheels will flop about and not hold their geometry
if u remove the rear dampers u can still drive the car just fine (it may be a little bouncy)
notice how i called them "dampers" NOT "shocks"
the springs absorb the "shocks" of the road
the gas and oil filled tubes "dampen" the oscillations of the springs and absorb NO SHOCKS
.....huh?
i though that shocks/dampers was an interchangeable term. how can you drive a fit without dampers?
Old Jul 15, 2009 | 01:35 PM
  #70
mahout's Avatar
A strut is a combined suspension part with the shock as seen on Fit fronts (Mcpherson the popularizer of struts says in his 'patent' for Ford). The Fit has struts in front and just shocks in the rear. Dampers are exactly the same as shocks; just England vs the world.
When most people talk about strut braces they are really talking about strut or shock TOWER braces. When you apply severe lateral forces on the struts mainly but also shocks/dampers braces will help maintain suspension geometery by holding the top of the tower in place. (they will move if enough lateral force is applied at the wheel).
They do nothing for Fits except add cute. Now if we had a 300 hp Fit, aks the Focus RS, braces would be good.
Old Jul 15, 2009 | 02:40 PM
  #71
eldaino's Avatar
thanks for clearing that up mahout. posts like his are what keeps the fit community scratching their heads and newbies clueless.
THEproFIT
29
May 1, 2011 01:21 PM
Benggolf
15
Feb 28, 2011 02:37 AM
Bragi
18
Jun 20, 2009 02:22 AM
vtecdreamer
Nov 11, 2007 09:52 AM
