Xenith Xenon Hid Bulb/Ballast?
Old Aug 7, 2009 | 12:35 AM
cKranez's Avatar
Ok so my left bulb/or ballast is not working im wondering if there is a way to find out which one is broken the ballast or the bulb? .. before i order a new pair any help !?
Old Aug 7, 2009 | 12:42 AM
cKranez's Avatar
ok update the ballast on the right gives out a humming noise.. but the left one doesnt.. soo is the ballast not humming because its broke n or is it not humming because the bulb ? lol
Old Aug 7, 2009 | 10:19 AM
nekret's Avatar
try swapping bulbs around and that'll give you your answer.
Old Aug 10, 2009 | 11:48 AM
xonexlifex's Avatar
try reconnecting everything, cleaning the wires and the connections, look at the bulbs and see if they look normal, the ballest usually doesnt has nothing to do with it, either they work or they dont, if it worked before than im sure its a bulb or wiring issue, try swapping each side and switching stuff around and seeing if thats it, try everything you can and then if nothing works than try contacting xenith xenons and im sure they could help you with the problem.
Luichenwai
May 26, 2009 03:19 AM
DrKelso
Apr 26, 2009 01:24 PM
xonexlifex
Nov 26, 2008 06:45 PM
loud_tiger
Sep 26, 2008 05:57 PM
Crawly
Jan 28, 2008 12:50 PM
