2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
DIY: 09 Honda Accord's Horn Upgrade
Old Sep 8, 2009 | 02:59 AM
  #41
Black3sr's Avatar
Yes, the low works fine by itself!
Old Sep 12, 2009 | 09:43 PM
  #42
southbound's Avatar
Thanks for the tip RetroFit. I did the swap today with no broken parts! Now I lay on the horn & still feel like I have a pair!
Old Sep 17, 2009 | 11:51 AM
  #43
Red 05's Avatar
I installed the Accord horn into mine, and while I'm happy that it's louder, I'm still going for the Nautilus air horn. Anyone else installed that horn into their fit?
Old Sep 24, 2009 | 03:33 PM
  #44
Edison Carasio's Avatar
Has anyone tried this on a GD Fit yet?
Old Sep 24, 2009 | 11:54 PM
  #45
sy11580's Avatar
actually the horn on the 07-08 Fit is the same one that you use from Honda Accord. but mind broken just 2 days ago, and it sound freaking funny. I order the air horn cannot wait to install
Old Sep 25, 2009 | 12:29 PM
  #46
manateerichard's Avatar
Exclamation Horn not working
So I did your mod, and found that my horn is not working, the Accord or the Original Fit, I checked the fuse and nothing! any ideas?!?
Old Sep 25, 2009 | 03:25 PM
  #47
gd3vbp's Avatar
I'll be picking up a pair of Hella Supertones when I get back from my camping trip this weekend.
Old Sep 25, 2009 | 03:57 PM
  #48
Black3sr's Avatar
OK so you plugged one or the other into the white electrical jack but have you mounted it to the frame? If not then it is not grounded and won't work..
Old Sep 25, 2009 | 05:12 PM
  #49
Yeah thats what I did originally, and I had no luck.
P.S. do u know where the horn relay is? I am thinking about checking that too.
Old Sep 25, 2009 | 05:19 PM
  #50
Black3sr's Avatar
Sorry no I don't. Mine worked fine when I replaced it .
Old Sep 25, 2009 | 05:58 PM
  #51
Smile
Nevermind on the relays. It was the grounding, when I first put it in, I only used pliers, on the second time i decided to use a 12mm wrench, now it works like a charm, great mod guys!
Old Sep 25, 2009 | 06:10 PM
  #52
stevet47's Avatar
Always use the right tool for the job.
Old Sep 25, 2009 | 07:19 PM
  #53
Black3sr's Avatar
People still use pliers on nuts these days I see.
Can we call him a tool?
Old Oct 2, 2009 | 11:19 AM
  #54
Roland's Avatar
Thanks for posting this DIY, it was a great help to me in completing this very quick project, worked perfectly. Another great reason to be a FitFreak member! What a difference it makes...
Old Oct 2, 2009 | 01:20 PM
  #55
Red 05's Avatar
I installed my Accord horn, and while it's in perfect working order, I still think I need something a bit louder, say, a Nautilus air horn. Anyone here installed one on a Fit?
Old Oct 3, 2009 | 07:02 PM
  #56
eswank's Avatar
I just installed mine today. Big difference. One thing... I broke two clips. Does anyone know where I can get those clips? I'm looking on HondaPartsNow and I can't seem to find it. Does anyone have the part number for them? Thanks!
Old Oct 16, 2009 | 04:27 AM
  #57
Palm Beach's Avatar
Honk honk!
Old Oct 19, 2009 | 06:57 PM
  #58
polokid69's Avatar
Originally Posted by IBJanky
Just ordered the Accord horn from hondapartsnow.com
I'll do the horn upgrade at the same time I install my new billet grille.
myke
did you install the billet grill ? Mine came with it and not very crazy about it.
Old Oct 19, 2009 | 09:29 PM
  #59
gd3vbp's Avatar
Just ordered my Hella Supertones last night. This should be night and day...
Old Oct 28, 2009 | 06:40 PM
  #60
polokid69's Avatar
Originally Posted by kroze
This is easy and can be done within 15 minutes. The 09 Accord's horn is much louder than the rinkydink Fit's horn. No longer where you'll be laughed at when they hear a freight train coming.
Materials needed:
- Flat head screwdriver
- 12mm Socket & Ratchet.
- 09 Accord's Horn (Part #38100-STK-A02)
- 15 Minutes.
First remove these 8 Clips using a flathead screw driver to get access to the stock horn.
Once you remove the panel, you have to remove these 2 clips in order to get to the 12mm bolt that's holding the horn.
Then remove the 12mm bolt
09 Accord's Horn vs. Stock 09 Fit
Put everything back together & voila, easiest upgrade ever.
thanks to your hands on instructions, I was able to change my horn out in 15 min this afternoon. I actially took my wireless netbook out to the garage to consult your pictures as I went along to make sure I didn't miss anything
