J2534 Reflash Possibilities
Old Sep 20, 2009 | 02:11 AM
  #61
sbualuba's Avatar
"Lek" say's
"I had a company do it for me.
They reflash the ECU to tune the fuel and ignition system to match the car, tuning includes released speed limit cut and rev limit cut, too. Oh and also close loop checking. There's no worry about honda warranty claim as they do not cut any wiring. They just open the ECU and connect the pin to read and write the data.
It take around 6 hours, because Honda's ECU is sealed with a silicone that is hard to open. They have to use a special chemical to open it, but it does not harm the ECU. It takes at least 3-4 hours to open it, after that they start to read and write the ECU to match the engine number, chasis number, immobilizer code and other technical stuff.
They also give a full warranty.
Watch this. It's the same thing, but the company dyno tested before and after. No problems at all. Just expensive, about $400 US. The only problem is opening Honda's ECU unit correctly on the GE Fit."
Old Sep 20, 2009 | 09:24 AM
  #62
ev8siv3's Avatar
When all is said and done, we should have a way to reflash the ecu without removing anything from the car. What they are doing is a serial solder to access the eeprom directly. This has been done with piasini tools as well. I'm hoping we'll have something to test with soon.
Old Sep 20, 2009 | 09:47 AM
  #63
Lek's Avatar
Lek
Actually, I don't know too much about the technical details of ECU reflashing, I'm just a driver like Lorenzo.
Anyway, Piasini Engineering, Italy is who did mine and loads of other cars in Thailand.
Just google Piasini Thailand.
Old Sep 24, 2009 | 12:59 AM
  #64
sbualuba's Avatar
any updates??
Old Sep 24, 2009 | 09:32 AM
  #65
ev8siv3's Avatar
Nothing much right now. I have been working with Epi to get the logger working with existing PID's. Once that is functional we would be able to locate additional PID's / parameters to log. It also supports many wideband o2 units.
I will check with Colby to see if there has been any progress on the kernel. I know he's been pretty busy incorporating the standalone SD card logging to the OP 2.0.
Old Oct 6, 2009 | 04:06 AM
  #66
totoro3744's Avatar
hi there, anyone has the drivers for OP2.0 to work with HDS?
can you please send to me? I would like to trick the ECU for and update as well. And also what kind of software needed to trick the ECU to read the wrong code?
Thanks
Old Oct 7, 2009 | 09:18 AM
  #67
ev8siv3's Avatar
The drivers are available here: openecu.org • View topic - Openport Stand-Alone Logging Beta
You will need a "Rev D" cable for it to work with HDS. If you look on the back of your OP 2.0 unit check for Rev C or Rev D. I cannot release any "tricking" firmware at this time as we are still in testing.
Old Oct 7, 2009 | 09:29 AM
  #68
totoro3744's Avatar
Hi there
Thanks for the reply.
Perhaps we can do something on the Fit. I have an idea to share on the tuning the Fit
It seems very positive with the trick to create an update for the CM Update
I will PM you the details so we can share more to release a tuning option
Old Oct 7, 2009 | 09:41 AM
  #69
totoro3744's Avatar
@ev8siv3
You got PM
I hope we can work together to come out with some tuning options
Old Oct 19, 2009 | 10:29 PM
  #70
sbualuba's Avatar
How's things going on? Haven't heard much lately
Old Oct 20, 2009 | 10:45 AM
  #71
ev8siv3's Avatar
Totoro and I have been working on something for the Civic and it may pan out to help with the FIT. The kernel for EcuFlash is still in progress. We're still making progress but it's slow!
Old Oct 20, 2009 | 11:14 AM
  #72
Lek's Avatar
Lek
I don't know how this stuff works, but I do know that since my re-flash the car pulls away much faster and on an expressway the RPM seems much lower at a high speed.
This is the amazing part, I'm getting an extra 2-3 km/L around the city and much better on the expressway.
Old Oct 20, 2009 | 02:13 PM
  #73
totoro3744's Avatar
hi guys
I am currently trying to develop an alternative flashing options for FIT and other honda cars, please stay tune
Old Nov 4, 2009 | 02:06 PM
  #74
ev8siv3's Avatar
If anyone out there has a JDM 2009+ Honda FIT, can you please grab the ECU Part # off of the label on the ECU for me? It will be something like 37820-XXX-XXXX
Thanks!
Old Nov 14, 2009 | 11:15 PM
  #75
sbualuba's Avatar
anything new guys??
Old Nov 17, 2009 | 06:47 PM
  #76
ev8siv3's Avatar
No news on the kernel yet. I have been successful with cross-market flashing so far with some tricks. Still working on various testing and waiting on the kernel for a full dump. I am in need of the various market part #'s for the 2009+ FIT's.
Old Nov 21, 2009 | 07:44 PM
  #77
awptickes's Avatar
Old Nov 21, 2009 | 10:22 PM
  #78
dtmbmw325i's Avatar
I am glad Honda stepped up the plate for an update for that. I don't know if that will help ev8siv3 with anything but thanks for the info. Can we just take this in and they reflash?
Old Nov 21, 2009 | 10:44 PM
  #79
ev8siv3's Avatar
Year/Model Program ID Program P/N
2009 Fit M/T P33050 37805-RP3-3050
2009 Fit M/T w/navi P33060 37805-RP3-3060
2009 Fit A/T and A/T Sport P33070 37805-RP3-3070
2009 Fit A/T Sport w/navi P34050 37805-RP3-4050
Now I just need a copy of the 37805-RP3-A050-M1.rwd file to update. Any other owner could simply make an appointment with Honda and take a copy of the TSB in for free service.
Old Dec 5, 2009 | 02:25 PM
  #80
awptickes's Avatar
Any updates?
