Brake Pedal not firm..
Old Sep 24, 2009 | 12:36 PM
Kurse's Avatar
I think i've a problem with my brake.
I've change the master this week(warranty power!!) I thinked it was the problem, but my pedal still not firm like i want, it start braking only at the middle of the travel of the pedal.. and i can push the pedal to the end of the pedal when i'm at a stop..
Here's my setup:
Hawk Hp+
Brembo plain
T1R brakeline
ATE Blue dot 4 racing
Brand new master cylinder (oem)
Someone have a idea?
Thanks a lot
Old Sep 24, 2009 | 03:23 PM
Black3sr's Avatar
Somebody forgot to bleed the lines after the change of the master?
Old Sep 24, 2009 | 04:16 PM
sounds like it. you probably got air in the system. check your fluid level. if it's a low (or gone) you'll need to bleed the brakes again from the beginning. you might want to have your dealer do it since they did the 'repair.'
or your slave cylinder(s) was the rootcause...
Old Sep 24, 2009 | 07:25 PM
Kurse's Avatar
it have no air in the system.. i've bleed it a lot of time..
Old Sep 24, 2009 | 07:34 PM
stevet47's Avatar
Its weird, and counter intuitive, but anytime I've switched from Dot3 to Synthetic Dot4 my pedal has always gotten more mushy. Maybe you are experiencing the same thing?
Old Sep 24, 2009 | 08:30 PM
redrumm's Avatar
thats not how mine is and we have pretty much the exact same setup. if i put it half way its firm and bites
Old Sep 24, 2009 | 08:49 PM
Kurse's Avatar
im starting to think the problem is the booster..
Old Sep 24, 2009 | 08:50 PM
Kurse's Avatar
redrummm: can you put the pedal at the floor when you're at a stop?
Old Sep 25, 2009 | 12:57 AM
redrumm's Avatar
no not really it gets really hard
Old Sep 25, 2009 | 05:42 AM
Black3sr's Avatar
I have no idea what you have done to the brakes but it sure is unsafe. Take it back to where you had the work done and get it fixed. If you did it then still take it to someone who knows brakes.
Somebody is going to be pizzed off if you run into the back of them besides the ticket you will get.
Old Sep 25, 2009 | 07:33 AM
Kurse's Avatar
Its Honda who have work on it :\
jfw432
May 25, 2019 08:04 AM
Gk5baby
Jan 6, 2017 07:29 PM
Santiad
Mar 19, 2013 03:01 AM
jazzplayr
May 12, 2007 06:37 PM
DavidB
May 4, 2005 11:16 AM
