Anyone know where the Fit's "Moby Dick" is?
Old Aug 4, 2006 | 06:13 PM
jrlnc's Avatar
Question Anyone know where the Fit's "Moby Dick" is?
I've mentioned elsewhere that I was buying a Scangauge. Well, it arrived today and I want to plug it into my Fit, but where?
The outlet is called the "Moby Dick", or OBDII or OBD2. I thought it would be near the interior fuse panel, but I pulled the fuse panel cover off and I don't see it anywhere. I'm not really sure what it's supposed to look like either.
Any ideas? I'm stumped.
Old Aug 4, 2006 | 08:15 PM
tubaman's Avatar
edit - thanks to a post on the Fitit Yourself Fitfreak forum I found it - wasn't easy! There is absolutly no mention of it in the owner's manual.
under the dash, driver side, near where the console passes under the dash, just above the accelerator pedal. You can feel a rectangular plug set into a shallow recess. I don't know if it is totally compatible with all OBD2 scanners - there is some further discussion on Fitit Yourself forum.
Old Aug 4, 2006 | 09:09 PM
sam's Avatar
sam
right side of the drivers side under the dash easily accessible.
Note: Do a search for several prior threads
https://www.fitfreak.net/forums/show...ighlight=ODBII
https://www.fitfreak.net/forums/show...highlight=ODB2
https://www.fitfreak.net/forums/fit-interior-modifications/5928-greddy-informeter-fit-no-go.html
Old Aug 7, 2006 | 02:30 PM
gsilvers's Avatar
Yea I posted this earlier in a bad spot but really if you're sitting in the drivers seat reach up and right where your right knee is and up theres the port.
Old Aug 7, 2006 | 04:52 PM
dacalac's Avatar
since it's already been covered I'll go ahead and lock this down. =)
SilverEX15
Feb 12, 2019 07:25 AM
billydee203
Jan 18, 2016 04:02 PM
m_x
Jan 16, 2016 03:55 PM
cph81
Jul 9, 2012 12:20 PM
secondspassed
Nov 6, 2009 12:20 AM
