L15a Frankenstein
Old 08-06-2015, 06:17 PM
kylerwho's Avatar
spoon fed
The I-dsi version has two valve thus promoting high swirl in the chamber so torque will be slightly higher but will taper off sooner than the vtec version that uses 4 valves to help widen the powerband.
Old 07-28-2016, 12:26 AM
Jdroj's Avatar
Talking Subscribing.. 😊
Hi guys.. Im also building a track car.. 😄 I'll learn a lot from you guys.. 😄
Right now i only have a stock gd3 L15, but im planning to get a GE8 1.3 m/t then import a GE8 RS engine with a 6speed m/ from japant.. Then from there increase HP by bolt on parts.. Hope you guys can help me, i will very much appreciate it..
Old 06-30-2020, 04:52 PM
Eliseo Cortes's Avatar
L15B7 cylinder head
Hi guys, do you know, if an L15B7 cylinder head, can fit in a L15A7 block?
Ali.K
11-08-2017 09:37 AM
GrocerySnake
15
11-03-2011 12:15 AM
Midnightfit
13
04-12-2008 10:50 AM
willem
01-29-2007 12:49 PM
007Fit
06-25-2006 03:10 PM
Quick Reply: L15a Frankenstein
