bolt on planning.....
Old Apr 29, 2008 | 06:44 PM
saiko's Avatar
Avid FitFreak Poster
So you're saying this
header -> test pip -> exhaust?
Cause you need a mid pipe there whether it be stock or after market. I'm not sure if the cat delete extends all the way to where the mid pipe ends but if it doesn't, meaning it stops where the cat converter is, then yes, you will need a mid pipe.
Old Apr 29, 2008 | 07:00 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by slip
okay.. so here's what's planned.
sw intake
wr intake manifold
wr race header
tanabe touring medallion
now originally, my question was do i have to get a b pipe to make the touring medallion fit? or should i just bolt straight on due to the race header's cat delete?
Most/all of the bolt on B-pipes adapt to the OEM muffler. Meaning itll adapt to any bolt on axle-back offered for the Fit.
Leaving the OEM B-pipe in and an axle-back will be low toned. Very low toned actually.
Id suggest the Aspec B-pipe, if they have them in stock.
Old Apr 30, 2008 | 01:59 AM
slip's Avatar
sorry i'm not wording my question properly.
what i'm trying to ask is will i need a bpipe to connect the race header to the touring medallion? or does the race header bolt directly to the exhaust due to the cat delete on the race header?
Old Apr 30, 2008 | 11:10 AM
saiko's Avatar
damn this is sooo hard to understand what you are saying.
wait... i think i understand...
the header comes on the cat delete?
in that case, the cat delete should just bolt on to the factory mid pipe, and you just bolt on the tanabe exhaust on to the factory mid pipe
is that what you are saying? hahah... i'm trying my best.
Old Apr 30, 2008 | 11:13 AM
slip's Avatar
why does my phrasing suck? lelel.
okay. take a look at the weapon r race header. here's a link for comparison purposes to a normal aftermarket header... https://www.fitfreak.net/forums/fit-...cs-inside.html
what i'm asking about the race header is this...
will an exhaust bolt straight up to the race header? or do i need some sort of pipe to connect the exhaust to the header?
Old Apr 30, 2008 | 11:48 AM
saiko's Avatar
hahaha i don't think my wording is any better
but here's the deal. this is how an exhaust works.
header/test pipe or cat converter/mid pipe/axle back
what you have there, in that picture, is the first two. it's a header and a test pipe (cat delete). all cars come standard with all four portions of the exhaust. so if you just replace the header and the catalytic converter, you will still have the stock mid pipe and the stock axle back
with me so far???
since the stock mid pipe will already be there, there is no need to buy another (only if you want), you can just take of the stock exhaust, bolt on the tanabe, and there ya go.
let me know if can clarify... anything else. hahaha
Old Apr 30, 2008 | 11:59 AM
slip's Avatar
lol. f uck it. i'll just buy stuff and hope it works. lol.
Old Apr 30, 2008 | 12:14 PM
saiko's Avatar
hahah it will. i'm just trying to clarify it.
just make sure... whatever you take out, replace it, or put it back in. lol
Old Apr 30, 2008 | 12:22 PM
slip's Avatar
lolol.
thanks for your help, and everyone's help!
Old Apr 30, 2008 | 03:37 PM
SD_MR_FIT's Avatar
yeah i would use the neo because of tuning reasons. i guess when you do a cat delete it runs super lean. so like thats super bad for the engine. you will get most gains by tuning it right, so you can actually make use of the cat delete.
and looks too is bonus..but really its about the a/f ratio
Old Apr 30, 2008 | 04:26 PM
slip's Avatar
idk man. i've read elsewhere that the piggybacks are shxxt and are completely worthless in the long run.
i'll try and find where i read it, but i don't wanna run a piggyback software anymore.
Old Apr 30, 2008 | 04:37 PM
  #32
vafitfreak's Avatar
piggy back is the only option for the fit because of the dbw throttle
Old Apr 30, 2008 | 04:59 PM
  #33
slip's Avatar
i understand that. i'm not doing boltons for
Kurse
Jul 16, 2015 07:33 PM
dewthedew
49
May 13, 2010 03:30 PM
ride_the_pony69
Aug 6, 2009 02:12 PM
setter11
May 4, 2009 01:43 PM
AtticusFit
29
Apr 27, 2008 01:20 AM
