auto to manual conversion
Old Nov 14, 2008 | 01:35 PM
Tofuman's Avatar
Originally Posted by Hondasforlife
thank you sir still sounds cheaper than getting a k20 swap which i would love but nah..i like my little l15 i still think it has potential
i think your best bet would be to sell your car private party, then buy a used manual transmission car. you should come out even if not ahead.
Old Jun 26, 2009 | 09:31 PM
Hondasforlife's Avatar
i have a friend thats going to swap my tranny for 400 and a couple of beers and i got the manual tranny for about 200 bucks and im getting the ecu with the key for about a 100 i just dont know what else i need lol other than clutch and flywheel
Old Jun 27, 2009 | 12:01 AM
FELIXY69's Avatar
Originally Posted by MarkyMark
The white extreme dimensions Fit has a K24 and manual trans and started life as an automatic.
but u see.... That fit don't use stock cluster and oem ecu any more !!!
Old Sep 2, 2009 | 06:30 PM
Edison Carasio's Avatar
I also regret buying a AT Fit. Thing with trading it is finding a MT that is worth the same as the loan on the car.
Old Mar 28, 2016 | 09:20 AM
Gandankenexperiment's Avatar
Hello folks,
Sorry for bumping a 7 year-old thread, but I'm planning on doing an A/T to M/T swap on my 08 FS, seeing that M/T fits are hard to find these day (at least in the model I want). I'm planning on picking up the parts from junkyard sales, or buying a wrecked fit on auction that has an intact front end.
Does anybody have any modern advice on this topic? List of parts? Trouble to look out for? Any help is much appreciated.
Old Mar 28, 2016 | 11:06 AM
gderf's Avatar
Originally Posted by Gandankenexperiment
Hello folks,
I think it will be more likely that you could locate a M/T Fit to buy, than it will be for you to find someone who has actually accomplished such an A/T to M/T conversion and who could guide you.
But if time and money are no object, then dive in. You could easily spend more than what your car is currently worth and be left with a car that is worth no more than when you started.
Old Mar 28, 2016 | 02:21 PM
bensenvill's Avatar
having done a swap on a different car, I can confirm that its definitely not worth the effort unless you are CRAZY attached to your exact car. I definitely spent more than the resale value of my car doing it. getting the trans, mounts and ecu arent impossible, you'll struggle getting clean wireharnesses for everything. you'll also struggle getting information on the details (especially the wireharnesses).
Old Mar 28, 2016 | 06:18 PM
dwtaylorpdx's Avatar
FWIW just thumbing though my electrical manual there are a bunch of differences between the AT and MT wiring harnesses, looks like MOST of the under dash and underhood harness would have to be swapped if you want everything to dial in.
Old Mar 29, 2016 | 12:26 AM
bensenvill's Avatar
yup, you will need all harnesses under the hood (and good luck finding a pick and pull that doesnt have something cut). But be prepared to pull the whole dash to replace the interior harness because its different with the clutch pedal.
It is not pretty, let me bluntly say, I walked into this conversion thinking I had every nut, bolt, screw and wire harness; and it ended up taking me 2 years to get it running.
Old Nov 9, 2016 | 11:38 AM
lakia5524's Avatar
I could probably get a diagram at work for parts I also have an auto fit wanting manual but my deal is its got kraftwerks, coilovers exhaust header and more i would have to swap on and back off
Old May 20, 2017 | 08:09 PM
lakia5524's Avatar
when you did the trans swap on the fit did you have to have the frame mounts modified or tapped to mount them?
Old Jun 8, 2017 | 03:05 AM
  #32
SycroFlow's Avatar
Anybody know the differences in the chassis? Mounting points for the auto trans vs manual?
Old Jun 8, 2017 | 07:13 AM
  #33
lakia5524's Avatar
im doing this swap in progress i beleave the drivers trans mount on the side may need
im doing this swap in progress i beleave the drivers trans mount on the side may need tapped haven't started on the auto yet
Old Jul 2, 2017 | 10:20 PM
  #34
lakia5524's Avatar
aright finished the swap today there is one mount that need 3 taps need all m/t mounts
oil pan engine harness ,dash harness clutch brake pedal pop out the auto bearing for the pilot bearing also hole saw clutch cylinder and i used the steering column from the other vehicle wouldn't work with original unless i towed it to the dealer to program the key
worst parts was the dash board and harnesses
Old May 23, 2021 | 12:36 PM
  #35
Jakecantsurf's Avatar
Originally Posted by Hondady
Come on guys, it can't be all that hard to do. It's more or less the amount of time and money you have to invest into it! I've done a couple auto to manual swaps in civics and integra's and they were not that bad. Just takes some time and money.
is anyone still here? I have a first gen fit I want to k24 swap, but it's auto and I have no idea where to start swapping a transmission with putting a clutch pedal in and all, if anyone is still active please help!
Old Jun 18, 2024 | 11:16 PM
  #36
aiken.GD3's Avatar
I am currently in the process of this swap, were you able to use the automatic ECU and it's wiring? also, what was the issue with the key? Was it because the immobilizer is linked with the TCM?
Old Jun 18, 2024 | 11:34 PM
  #37
aiken.GD3's Avatar
Lightbulb 2024 auto to manual conversion
I feel you! Did you end up being able to do the swap? I am still working on the manual swap myself. I've gotten to the point now where my next step now is either changing steering column, harness, etc. or figuring out a way to do some pin outs to be able to leave the stock auto harness. I've heard word from some K Swap people locally that they've gotten away with the automatic harness and was successfully able to trick the ECU ino thinking it was constantly in nuetral. Any help would be great from anyone! I have an entire manual parts car, and I am really deep into this right now and willing to do the work. I just want to get this done as fast as possible. Having messed with most everything except for wiring, I am out of my comfort zone. I am currently making a youtube video series on this swap, as I've seen there is a lot of people wanting to do the same thing using crashed manual fits, any info helps.
carolus17
Oct 23, 2012 09:58 PM
twotonezed
Jan 27, 2012 09:44 PM
xxmostwantedxxx
15
Jun 23, 2008 08:37 PM
donaldmejr
May 10, 2008 03:07 PM
SoccaBoi
13
Nov 21, 2007 01:21 AM
