Endlink noise
Old Sep 16, 2008 | 07:51 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Originally Posted by kenchan
you might even want to consider adding some silicone
lube at both ends of the spring...that will at least help eliminate the
sudden movement in the spring which reverbrates into that noise.
Thats what Im going to try first.
It really is a hard sound to describe. Its like a light click with a mixture of spring tension.
Old Sep 16, 2008 | 08:01 PM
Jazz GD3's Avatar
Hmm, mine seems like it doesnt make a thuck noise, but a CLICK. But weird, it happens with the same causes? Like driving slow backing into the driveway, and turning at slow speeds. Mine a different problem? I only have lowering springs on my car, so maybe its the perches? But again, its not a thuck.
Old Sep 16, 2008 | 08:36 PM
Posts in the NUUDE
This is for coilovers. Completely different.
Your problem is probably the spring clips at the top of the springs.
Old Sep 17, 2008 | 12:12 PM
GD3_Wagoon's Avatar
well, i had some extra time on my hands yesterday so i began investigating the THUCK/CLICK noise...
SHG_Mike and Kenchan... you guys rock
i pulled out the shock and tightened the nut on the lower portion of the top mount (you were right kenchan, it is a 19mm nut). while the endlink was off, i went ahead and added the extra washer for s.hits & giggles.. tadaaa NO MORE NOISE
thanks, everyone, for your suggestions! i'm sure they'll help someone (like myself) down the line
Old Sep 17, 2008 | 12:23 PM
hey no noise sounds good!
Old Sep 17, 2008 | 12:53 PM
GD3_Wagoon's Avatar
thanks again kenchan
Old Sep 17, 2008 | 12:55 PM
Old Feb 24, 2009 | 05:25 AM
naszero's Avatar
Is there a guide on how to do this? I have the exact same noise coming some the exact same side (passenger). I'm riding on Skunk2's Pro-C's also
Old Feb 24, 2009 | 10:10 AM
not really a guide, but you will have to remove the strut
from the car, remove the top mount, and tighten the
nut below on the piston shaft. it's not hard to do, just
time consuming.
and dont let that knuckle fall off your lift or box or watever
you are using to hold it cause it will disconnect the CV joint
to make a 15-20min job into a 1hr+ job. lol hahahahaha
Old Feb 24, 2009 | 11:34 AM
FitVic's Avatar
You talking about axel pop out?? Lol we'll I hear the sound from my passenger side also. I'm gonna go back and check it out.
Old Feb 24, 2009 | 11:43 AM
GD3_Wagoon's Avatar
before tearing the suspension apart again i would first try adding some more spring tension. after i had "fixed" the noise, i still had a few hints of it when going over bumps/driveways with the wheel turned. i added more spring tension and that did the trick.
Old Feb 24, 2009 | 11:46 AM
  #32
^^ yah preload is a good thing to have to prevent spring rattle.
thanks for the rep btw!
Old Feb 24, 2009 | 11:53 AM
  #33
GD3_Wagoon's Avatar
^^ spring preload, ahh thank you! damn, i was racking my brain trying to remember the correct terminology for my last post LoL
no need to thank me for the rep
Old Feb 24, 2009 | 12:13 PM
  #34
FitVic's Avatar
Will do ladies. After some fender rolling and cars done from repairs I will go lower and fix the preload
Old Feb 24, 2009 | 05:23 PM
  #35
fitinfit's Avatar
T1R front swaybar+ skunk2 ProC ...yea i have the noise tooo, it doesnt bother me lol
Old Feb 24, 2009 | 07:24 PM
  #36
GD3_Wagoon's Avatar
^^ i tried to live with it too but it bugged me enough to try and fix it.
i'm really diggin' your wheels! are those kosei's? they look like it, but i'm a wheel noob and could be wrong.
Old Feb 24, 2009 | 07:36 PM
  #37
fitinfit's Avatar
yea, great price, light weight, and made in Japan!
Old Feb 25, 2009 | 12:34 PM
  #38
Originally Posted by fitinfit
and made in Japan!
so it rattles?
El Chupacabura
Feb 10, 2011 10:08 AM
ToyotaFIT
Oct 23, 2010 04:19 AM
aZnCdn
Mar 27, 2010 07:53 PM
kingofpicklez
Nov 22, 2009 03:31 PM
