Brake pad replacement question.
Old Oct 13, 2008 | 02:44 PM
sk4tec's Avatar
Hi guys, I'm a newbie.
I've got a UK stock Jazz (or Fit as its known) 1.4 Sport CVT. I had some new tyres put on it. I had a quick peek at the pads and it looks like its got 1 cm ~ 0.39 " left of material on it.
Do they need to be changed or should I wait for this brake pad warning noise? I presume its a metal spring of some sort which will hit the disc when its close enough and make a noise right?
Old Oct 14, 2008 | 12:48 PM
i usually just keep an eye on the gap between the wear indicator and the rotor.
if you see a decent gap there, should be no problem given that you're on
stock brakes and dont track your car.
nigel_nz
Aug 10, 2016 03:19 PM
ktbishop222
May 22, 2014 05:12 PM
Santiad
Sep 8, 2012 02:34 PM
garciabe
Oct 7, 2007 06:46 AM
RkFast
Jun 23, 2005 10:57 AM
